Author Topic: 2.5 v6 abs  (Read 1772 times)
rosco329
  • United Kingdom
    • Mk2 cav turbo
2.5 v6 abs
« on: 31 December 2013, 17:16:26 »
Hi, new to the forum and i have recently acquired a 2.5 v6 manual estate and it has the ABS light and TC light on, i am also getting no communication between the abs ecu and a snap on scanner. i understand that this usually means new ecu time. In preparation i pulled out the old ecu and began looking on ebay for a new one. I'm a bit confused about which one i need, i know that unless i get one from another 2.5 v6 manual it will need reprogramming. However, i am wondering if i could use one from a 3.2 v6 and get that reprogrammed, or does it need to be from an x30xe or x25xe engine car? The part no. on my current pump is 0 273 004 206. Does anyone know if this is correct for the car?
Many Thanks
Ben
Re: 2.5 v6 abs
« Reply #1 on: 31 December 2013, 20:18:17 »
What age is it?
rosco329
  • United Kingdom
    • Mk2 cav turbo
Re: 2.5 v6 abs
« Reply #2 on: 31 December 2013, 21:01:52 »
2001
tidla
  • solihull
Re: 2.5 v6 abs
« Reply #3 on: 01 January 2014, 00:01:42 »
Had the same dilemma when mine went south. Fitted one from a 2.5 non matching part no off ebay.
I expected strangeness which would result in diagnostic adjustment, but all seems ok..
rosco329
  • United Kingdom
    • Mk2 cav turbo
Re: 2.5 v6 abs
« Reply #4 on: 01 January 2014, 00:42:12 »
Many thanks those who have replied. I have ordered one from a 3.0 it has the same part no. but a different IDENT (DJ as opposed to DX) Vaux EPC states it should be a DX for both x25xe and x30xe. I have access to "My Naff Code Reader" so hopefully i will be able to interrogate the ecu once it is in the car and have a look and make sure its working.
Thanks again
Ben
Re: 2.5 v6 abs
« Reply #5 on: 01 January 2014, 11:48:01 »
What age car did the donor part come from, it has to be 1998 or later.
Avoid any programming options with that code reader of yours...
Re: 2.5 v6 abs
« Reply #6 on: 01 January 2014, 13:09:11 »
You could have sent your original one to these guys for repair.  ;)
http://www.bba-reman.com/UK/index.aspx
rosco329
  • United Kingdom
    • Mk2 cav turbo
Re: 2.5 v6 abs
« Reply #7 on: 01 January 2014, 17:06:18 »
The part i ordered is off another 2001 car. Ive used "My Naff Code Reader" quite a bit on other cars and know to stay away from using it for programming... ask me how i know... When it required programming ill either go to drive vauxhall in aldershot as they are fairly helpful or try and find someone local to farnborough with tech2
Ben
Re: 2.5 v6 abs
« Reply #8 on: 01 January 2014, 17:13:44 »
Should be fine. Cant remember if that one needs programming for engine type.
Kevin Wood in Alton is the nearest Tech2 I know of...
Page created in 0.034 seconds with 16 queries.
