Burning smell at speed
Started by Webby the Bear, 02 January 2014, 17:07:30
Webby the Bear
Hi guys,
Was driving at a steady 85mph on my private track in my mum's Ford. Burning smell appeared. Dropped speed and it went away. Went back up to and it came back..... wtf?
The only thing I can think of is checking for any wires coming in to contact with the exhaust manifold.  :-\
Any other ideas?
it was defo not coming in from outside..... it did it again when I tested it today.
RIP Paul Lovejoy
AndyRoid
Quote from: Webby the Bear on 02 January 2014, 17:07:30
If a cable has made contact with anything remotely hot, then it will be stuck there no matter what speed you do (and hence, smell).
Outside shot, but maybe a head or rocker gasket that is a bit weak when the oil pressure gets ramped up and is spurting on to the exhaust manifold?
Webby the Bear
Quote from: AndyRoid on 02 January 2014, 17:16:13
Thanks Andy. I'll get a butchers around the Fanny-mould. See if anything's untoward :)
RIP Paul Lovejoy
Not forgot to turn off the heated seat have you webby ;D ;)
I would be thinking slipping belt first, particularly as it went off when you reduced speed...... :-\ :-\
Webby the Bear
Haha luckily Phil this car doesn't have them... or at least I don't think it does  :o ;D
Quote from: Vamps on 02 January 2014, 21:48:40
That's an excellent point! Only problem is the aux belt needs special kit to get off/on. Would there be signs I can look out for of a slipping belt? And I'm presuming we're talking aux belt and not timing belt bearing in mind the car runs very sweet?  :)
RIP Paul Lovejoy
Only burning that worried me was in the Omega that day , you kind of know what sort of different smell rubber gives off .. tyre smoke being different from aux / cam belt smell  :o
Or like engine oil burning is a different smell to gearbox . Diff oil stinks  ??? ;D Having owned a few Fords the smell of oil became a regular occurrence especially in the Mk 3 escort  :(
AndyRoid
Quote from: Emd on 03 January 2014, 17:46:36Having owned a few Fords the smell of oil became a regular occurrence especially in the Mk 3 escort  :(
The MK3 had to be the biggest (and weakest) piece of crap from the Escort line IMHO.
martin42
Quote from: AndyRoid on 03 January 2014, 18:11:20
My Mk3 wasnt too bad , used 4 litres of oil a month  ;D Luckily i had an endless supply of machine oil at the time  :-X
Keith ABS
  My Mk3 used 2 litres a week. Almost a two stroke mix ratio :)
Keith B
Car should still be under warranty steve no ?  :-\
