New Elite Project
Started by JamesV6CDX, 04 January 2014, 00:00:18
Given the extremely generous price, and the fact it was clearly an honest, no nonsense deal, I have purchased Chris H's Elite
I didn't need, wasn't even sure if I wanted it, but at that price (£200!) and being fairly local I'd have been daft not to take it. I'd been after a set of 17 inch wheels for my 2.2 and originally I was intending to buy it purely to have those, and then break/scrap/sell on
I will post up some pics tomorrow, but having seen, and since now driven the car, there is just no way I'm breaking it. It would be criminal, because it really is a beautiful example, of which some TLC from an enthusiast will see it back to full glory as an almost pristine facelift Elite
So firstly - thanks to Chris for the sale, a very genuine chap and a deal I'm chuffed with.
The work that needs doing, is:
First and foremost - MOT, so It's mobile if needsbe.
- Rear OS wheelarch has rust bubbling through at the very lower part. This is the worst of the two, and the lip inside the wheelarch you can easily peel away if you want to due to rust. The rear NS one is not that bad, but still needs attention.
- The gearbox needs looking at. If you accellerate from just rolling, to around 35mph, let go of the gas, it seems to hold it in gear far too long, before the revs then drop with a good old clunk. To be honest under normal driving  conditions the average driver wouldn't notice it very often, but I've driven loads of V6 Omegas, and I know it's not right. I'm yet undecided on cause, but I'll investigate at the start, eg check fluid, check for any remains of thrust washer, then move on to soleniod operation etc. No biggie at all.
- Possible - but not yet looked at / confirmed coolant issue. The only real reason I say this is because there is absolutely no pressure in the system after any sort of driving, even an enthusiastic run. I'm wondering if maybe the cap isn't sealing, or if there is a small leak somewhere, as it should be holding pressure. So this'll need looking at. The temp is OK, it creeps up below the 100 but the fans soon bring it back to the 95 as they should. But the top hose etc can be squeezed right up, as if there's no pressure.
-Tyres on the front wearing on inside edge. The usual. Probably 'Bones and WIM. The Bones are Gen GM and only a year or two old, having covered 60k. I might look at Poly bushes.
- Bumper on rear has a nice split! Replacement purchased, just needs painting and fitting, can do that at leisure.
- Couple of v small isues, .Eg an eleccy window switch.
It might sound like a lot, but, you have to consider firstly the very sensible price of the car, and secondly, the fact that as an enthusiast, it's nearly all work I can competently do, so will cost me no more than my time and a few parts.
There is no rush to get this all done - it's not my daily driver so I can tinker at my leisure.
I will give it a proper going over when it's dry and daylight and report further.
My plan is to do a few bits here and there, and not rush it, so I keep motivated, until it's back to it's former glory. I'll decide it's fate then, although it may turn out to be a 2.2 replacement in the summer.
On the plus side. The engine, (3.0) is absolutely sound, it pulls like an absolute train. The interior (creamy leather) is almost immaculate, it's not been smoked in or abused, and it's just a lovely, lovely car.
Really pleased, thanks again to Chris, I'm looking forward to playing, it's my first real project in three years :)
Thread will be updated with progress.
Does anyone have any experience with wheelarch repairs, I'm after a permanent repair, which may have to involved someone cutting/welding in new metal
Any advice more than welcome :y
Sounds like an excellent investment, Mr James. :y
ted_one
carz2.co.uk is where I've managed to get my wheel arch replacement panels, they have them in stock and with delivery they come in at around £32.00 each. Two of my cars are going in for them to be replaced,cost for one car which includes respraying front and rear bumpers and replacing the n/s rear wheelarch is £750.00,so not a cheap exercise,second car is having both arches and a full respray cost £1800.00 but could nudge up to the 2 grand mark.I should be seeing you quite soon James and can put you in touch with the guy,but I would think you would still be looking at £250-£300 a pop.You might also speak to Josh as he has a body man who is quite reasonable :y
Quote from: JamesV6CDX on 04 January 2014, 00:05:24
I've recently had both rear arches done, along with the LPG filler, for rust, plus a couple of supermarket dings sorted .. cost £800 !!!! However, the guy I use has very high standards ... no cheap jobs there !!...
Rods2
I wish you all the best with your new project, please post some before and after pictures and maybe a how-to on rear wheel arch replacement.  :y
James, when you say the lower arch, do you mean inside the door shut? That's not a difficult repair; mine had a huge rust bubble which took about an hour to cut out, make and weld in a patch, and grind the weld down. It still needs finishing, but I've other priorities.
I reckon I could make repair panels for the upper arch, between the door and the bumper, in about 45mins for both sides. It's a simple shape, perfectly suited to a hammerform, which is two pieces of MDF cut to the required curve, between which the metal is clamped and hammered to shape. I've recently done this for a repair to a Transit front inner arch, which took about half an hour. I still have the other side to do, but the hammerform will do that easily. A fiver's worth of metal is probably enough
Unless the arch is really badly rusted, I'd expect to weld the repair to the upper curve where it flares into the quarter panel. If carefully welded, this would need very little finishing before paint.
Thanks for all the info and opinions
MOT booked for first thing tomorrow!! :y
Quote from: JamesV6CDX on 06 January 2014, 09:38:56
James, your Inbox is full so I have emailed you via your Website address ::)
Kind Regards, Phil. :y
Just given her the once over in prep for tomorrow's MOT
The wishbones, idler, brake pipes, pretty much everything appears in good fettle
Fingers crossed :y
Toledodude1973
Never know you might come down Ipswich in it :y :y
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Shackeng
Quote from: Entwood on 04 January 2014, 16:48:16
If that was Ady Nige, I agree, he's not cheap, but does a first class job. I had the classic rust patch around the rear wiper on the estate. I had it done by another guy, after 2 years it was back. Ady did it again 5 years ago, still sound. You get what you pay for in most cases. :y
PS Isn't it 12th night yet?
Toledodude1973
Its always Christmas on OOF :y
chrisgixer
Ime, re wheel arches/rust, once the metal is exposed to the air and the galvanised finish is broken, any repair will rust back through. Its just a question of how long it lasts.
blackviper90210
Quote from: JamesV6CDX on 06 January 2014, 17:22:24
Fingers crossed :y
Good luck with the MOT James :y
AKA - Mr Bracket
