Pages: [1] 2 3  All   Go Down
Author Topic: Smell of oil, bemused! Any ideas?  (Read 7171 times)
The Waynester
  • Oxfordshire
    • 1998 Omega 2.5 V6 CDX
« on: 06 January 2014, 02:26:06 »
Hi Everybody
Happy New Year and long time no speak
My Miggys still going strong and drives great
Good old Symes did tracking for me recently and a full service on her
I've got a problem though, while driving her she's fine, but when coming to a stop or sat at lights etc, I get a very strong whiff of oil!
Driving me insane as Syme recently cleaned my breathers out and she goes much better
The smell of oil has only started after I had an oil change
Any ideas why I'm getting this whiff which has lasted about 6 weeks??!
I've got no steam coming from the rocker covers
Symes gonna look at these next Sunday
But thought I'd ask on here incase anyone else has ever had this Oil whiff!!? lol
chrisgixer
Re: Smell of oil, bemused! Any ideas?
« Reply #1 on: 06 January 2014, 02:33:37 »
Usually failed cam cover gaskets leaking oil on the manifold heat shield, drivers side is in front of the pollen filter to the cabin. Air flow does the rest.
The Waynester
  • Oxfordshire
« Reply #2 on: 06 January 2014, 02:37:31 »
Okey dokey
Even though theirs no effect on performance of the car?
When I do have new ones put on
Will I notice a difference in MPG and anything else?
The Waynester
  • Oxfordshire
« Reply #3 on: 06 January 2014, 02:38:33 »
How much is all the kit i need from Vauxhall?
chrisgixer
« Reply #4 on: 06 January 2014, 02:40:55 »
Okey dokey
Usual detriment is missfires caused by oil leaking into the spark plug wells. If its running fine that suggests its only the outside edges of the cam covers leaking, or the oil hadn't eaten the spark plug lead caps yet.
Unless its misfiring, you will notice no problems at all. ...apart from the smell of oil of course ;D
...is the oil cap secure, along with the filler neck?
chrisgixer
« Reply #5 on: 06 January 2014, 02:42:50 »
£70/80 from vx only for the gaskets. If the leads are buggered price them up from a factors. Euro car parts do a set for under £50 last I looked. Dont use vx for leads they are over £100 a side.
chrisgixer
« Reply #6 on: 06 January 2014, 02:44:12 »
Ps. Don't panic, it's fairly normal on these. But don't leave it, deal with it ASAP. 6 weeks is too long really Wayne. ;)
The Waynester
  • Oxfordshire
« Reply #7 on: 06 January 2014, 02:47:08 »
Cheers Chris :y
Syme did check for oil in the plug wells about 2 weeks ago, all clear mate
Hopefully can get it sorted next Sunday
I've noticed the idling revs going up and down when stood still
Hopefully when gaskets are replaced, she'll go even better
The Waynester
  • Oxfordshire
« Reply #8 on: 06 January 2014, 02:48:27 »
I only do 40 miles a week over 4 days
So I'll try not to drive her until my drive to Oxford next Sunday
(About 22 miles)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #9 on: 06 January 2014, 08:23:00 »
You should clear the breathers at the same time as replacing cam cover gaskets. The gaskets blow when the breathers are blocked and the crank case pressure finds some other way of escaping.
The Waynester
  • Oxfordshire
« Reply #10 on: 06 January 2014, 08:54:28 »
Breathers been done mate, they we're full of crap.. They we're done about 3 weeks ago
The Waynester
  • Oxfordshire
« Reply #11 on: 06 January 2014, 09:53:22 »
Rang Vauxhall, told me the gaskets and o rings don't come with sealant and it's not needed?
Is this True?
Price for the above including VAT is £101 ouch!!!
« Reply #12 on: 06 January 2014, 09:56:02 »
Have a look for the oil leak before buying any parts. Given that it started when the oil was changed, I'd make sure the oil filter housing is not leaking. ;)
The Waynester
  • Oxfordshire
« Reply #13 on: 06 January 2014, 10:02:41 »
Okay mate
« Reply #14 on: 06 January 2014, 10:21:06 »
Got the same happening on mine . No apparent leaks and only oily smell when pulling up after running  :(
Pages: [1] 2 3  All   Go Up
