Pages: 1 2 3 4 [5]  All   Go Down
Author Topic: Shall i fit LPG??  (Read 9505 times)
Dazzler
  • Haverhill, Suffolk
Re: Shall i fit LPG??
« Reply #60 on: 04 June 2008, 16:01:00 »
Well, the deed is done. One V6 Front end and 4 hole 80 litre tank winging its' way to me. I will make it all fit somehow, even if I have to ditch the removable towbar for a shin breaker.  ;)
Went for a 4 hole tank because the single hole multivalve is marginal with the 3.2's output power according to Jeremy due to the fact that they have a 6mm liquid pickup pipe in the limited available space. Although I may well have got away with it in practice I don't like engines going lean at full throttle. Added advantage is that the filler valve is bigger bore, too, so it will fill faster. :y
A bit of fun and games ahead for me.  :)
From my previous experiences with LPG , as you start to travel more than before consumables costs ( ie brake pads, filters, oil and sparks ) increase ..So total cost again is same  ;D :y
So does LPG knock out the oil and plugs prematurely then???? :-/
Does it knock out the engine as well (head and valves)??
« Reply #61 on: 04 June 2008, 16:36:17 »
Kevin,
Would you mind sharing the cost with me please??? You can PM it if you like. Just want to know what figure I'm looking at saving up before I can do mine!! I'm planning to be able to do it during August, when the weather is supposed to be good!!  ;D ;D ;D
trebor
  • Swindon
« Reply #62 on: 04 June 2008, 19:10:24 »
Use NGK Iridium LPG plugs :)
Pages: 1 2 3 4 [5]  All   Go Up
