Ford Ka
Started by Shackeng, 09 January 2014, 17:40:35
Shackeng
Some hit-and-run lunatic hit my son's parked Ka so hard it has bent a wheel and the steering knuckle. He has sourced a replacement knuckle. Has anyone experience of changing these? Any special tools required?
We hope to do it in my garage this weekend. :y
martin42
Should be straight forward
Shackeng
Hub nut is 270NM!
martin42
Ah yes thats about right for fords.
Webby the Bear
Hub nut was done up to that torque on my mum's Ford Fusion....came undone no problem with full weight on breaker bar  :y
RIP Paul Lovejoy
Shackeng
Quote from: Webby the Bear on 09 January 2014, 19:12:48
Thanks Webby. :y
MR MISTER
Quote from: Shackeng on 09 January 2014, 22:38:19
Thanks Webby. :y
Thats Webby's full weight. You may need the help of a friend.
Althoguh you can get considerably more force by pulling upwards on the end of a breaker bar than even a heavy person stood on one.  :y
I_want_an_Omega
Quote from: Shackeng on 09 January 2014, 18:43:31
Hub nut is 270NM!
Isn't that the cam cover bolt torque ?  :-X
Quote from: Lincs Robert on 10 January 2014, 09:40:44
Hub nut is 270NM!
Only if you've got Vectra alloy covers and those new fangled pressure relief valves!!  ;)
Shackeng
I forgot to mention that son took the limping Ka to a garage near him for an assessment, and they decided it needed a ramp to check, so they phoned Imperial Tyres Swindon, who do alignments, who agreed to look at it. After son very courageously limped across town for the inspection, they put it on the ramp and identified the damaged knuckle, and managed to straighten it out somewhat. The point of this post is they did about 45 minutes of work and did not charge a penny, which, in these days, is above and beyond, so many thanks  to Imperial Tyres for helping out. :y :y :y
Webby the Bear
Great stuff mate! You are spot on: in this day and age no one does something for nowt...especially 45 minutes' work!
Does it drive perfectly now then?  :y
RIP Paul Lovejoy
Shackeng
Quote from: Webby the Bear on 12 January 2014, 11:14:45
Unfortunately not, although it is now driveable. It still requires a knuckle change, son has one coming from the Bay for £21.60! How good it is remains to be seen, but it will be better than the one it replaces. :y :y :y
Webby the Bear
Quote from: Shackeng on 12 January 2014, 11:33:27
Does it include a bearing assembly mate?
RIP Paul Lovejoy
Shackeng
Quote from: Webby the Bear on 12 January 2014, 11:43:51
Pass. I haven't yet seen the car or what has been ordered. I'm assuming son has ordered what is needed, but this may not be the case. ::) :y
