Oh dear......What have I done?
Started by Field Marshal Dr. Opti, 10 January 2014, 10:45:36
chrisgixer
The Ls engine being set and more reliable perhaps? What's the Merc v8 got? Dohc chain driven?
Quote from: chrisgixer on 10 January 2014, 15:32:26
SOHC chain driven......and it gets by on only 3 valves per cylinder.....24 rather than 32.
I'm not sure which valve is missing......inlet or exhaust?
It's certainly in a low state of tune producing barely 60 BHP per litre. :-\
It does have 339 lb ft of torque by means of compensation though. :y
chrisgixer
Quote from: Mr. Opti on 10 January 2014, 15:37:30
Wonder if the software can be upgraded? Like the BMW 2.5 lump is a 3.0 with detuned software. Wack the 3.0 software on and away you go, 3.0 in your 2.5.
Quote from: chrisgixer on 10 January 2014, 15:43:46
Hmmm. Sounds tempting, Mr Gixer. As I said before, it is the 'runt of the litter'.....later CLS models having 5.5 litres and another 80 BHP before sticking a supercharger on it.
It will have a single exhaust valve and twin inlets, easier to pump exhaust gases out than to suck air in.
Quote from: Marks DTM Calib on 10 January 2014, 15:56:40
Is there anything you don't know about cars and trains, Mark?... :) ;D :y
Would the exhaust valve be bigger than the inlet valves to compensate?  ???  :-\
Quote from: Sir Tigger on 10 January 2014, 16:17:41
I don't know, Tig :'(
But anyone who owned a Honda Wet dream/Superdream  will be familiar with three valves per cylinder.
Exhaust valve area will be proportional to the total inlet valve area so in this case, it will be equal to or slightly larger I would expect.
tigers_gonads
2 small inlet valves
1 large exhaust valve on those engines  :)
Little bit like this (perhaps larger exhaust valves) - these are '05 Mustang heads:
1. this monster can easily be tuned..  but I doubt you will need that..
2.if you try hard it can easily go down to  single digit consumption figures..
3. keep those winter tyres until end of march .. on a frosty road it may save you from high expenses..
Glad you buy that toy..  enjoy :y
