Oh dear......What have I done?
Started by Field Marshal Dr. Opti, 10 January 2014, 10:45:36
Quote from: Andy B on 10 January 2014, 19:26:54
Quote from: Mr. Opti on 10 January 2014, 15:37:30....
It does have 339 lb ft of torque by means of compensation though. :y
is that all  ::)
http://www.parkers.co.uk/cars/reviews/facts-and-figures/mercedes-benz/r-class/estate-2006/33419/
376 lb ft.......Ah yes, the joy of big torque from a turbo diesel. :y :D
Only 220 BHP though...... :P :P :P :P
tigers_gonads
Talking about diesels, always fancied a drive in one of those VW / Audi's with the V10 turbo diesel under the bonnet.  Over 700 nm of torque I believe  ::)
Quote from: tigers_gonads on 10 January 2014, 20:20:53
In old money please, Mr Gonads.
Newton metres mean nothing to a sad old bastard like myself. ;D ;D ;)
tigers_gonads
Quote from: Mr. Opti on 10 January 2014, 20:23:38
Didn't know you was sad  :P ;D ;D
Quote from: Mr. Opti on 10 January 2014, 20:17:09....
it's actually 224   ;D..... but I won't split hairs ..... not bad for a diseasal   :y :y
Quote from: tigers_gonads on 10 January 2014, 20:30:46
Not as sad as he'll be when Mrs Opti finds out  ;D
Quote from: Marks DTM Calib on 10 January 2014, 16:51:20
Exhaust valve area will be proportional to the total inlet valve area so in this case, it will be equal to or slightly larger I would expect.
So what's the advantage of having two smaller inlet valves and one big exhaust valve, over 2 valves the same size?  ???  :-\
chrisgixer
#52
Quote from: Sir Tigger on 10 January 2014, 23:34:26
Guessing the two valves have a bigger over all area. There's a limit to the size of two holes within a single bore/head. So a way to get a bigger aperture is to have two holes.
Not sure if another valve would need another cam follower, and hence another cam to run it, due to space on a single cam. Probably.
My understanding is better fuel/air mixing within the cylinder, so giving a "better" spread of flame front / combustion, so increasing efficiency.
If all the fuel/air comes in through one valve it "sits" centrally in the cylinder, two valves ensures better "mixing".
This is all based on what I was told many years back when I asked the question .... no proof whatsoever so may well be totally wrong ...  :)
Quote from: chrisgixer on 10 January 2014, 23:41:02
Yep, or more correctly, the cylinder of air gap that's exposed when the valve opens with a given lift is much bigger for a given space in the head when you fill that space with 2 small valves instead of one larger one. You also get better "swirl" which means better mixing of the fuel air mixture in the cylinder and more even filling.
Yep, it'll certainly need its' own lifter (hydraulic or manually shimmed) to set the clearance. Most have their own cam lobe.
