Author Topic: waterpump ?  (Read 3067 times)
samrey4u
  • norwich
  • Big stranglers fan
    • 2003 2.2 cd saloon
waterpump ?
« on: 12 January 2014, 12:13:57 »
Losing water . Nothing on dipstick or oil filler cap , no leaks visable advice please guys
sam
Re: waterpump ?
« Reply #1 on: 12 January 2014, 12:20:52 »
Need to pressure the system and have a good look around. Heater bypass valve is a likely culprit
How much are you losing?
samrey4u
  • norwich
Re: waterpump ?
« Reply #2 on: 12 January 2014, 12:22:42 »
Put a litre in yesterday and same today
sam
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: waterpump ?
« Reply #3 on: 12 January 2014, 12:25:05 »
Check HBV
RIP Paul Lovejoy
Re: waterpump ?
« Reply #4 on: 12 January 2014, 12:26:25 »
Crickey should be easy enough to find then!
You had a good look around the back of engine with a torch?
Any water in footwells?
Any excess steam from exhaust?
Is the temp gauge and coolant pressure ok?
In the meantime don't top up with neat water especially at this time of year :y
samrey4u
  • norwich
Re: waterpump ?
« Reply #5 on: 12 January 2014, 12:27:03 »
Check HBV
where is hbv located im useless lol
sam
Webby the Bear
  • Northampton
Re: waterpump ?
« Reply #6 on: 12 January 2014, 12:29:05 »
Drivers side, back of head under the scuttle. Play about with heater settings with car running. Look in't Maintenance Guide for a how-to if you find it's leaking.
RIP Paul Lovejoy
samrey4u
  • norwich
Re: waterpump ?
« Reply #7 on: 12 January 2014, 12:30:12 »
sam
Re: waterpump ?
« Reply #8 on: 12 January 2014, 12:31:45 »
Drivers side, rear of engine. Looks like a spaceship! Has three pipes connecting to it and a small vaccum pipe on top. Try running the engine on hot and cold cabin temperatures as it may leak on one setting and not the other :y
samrey4u
  • norwich
Re: waterpump ?
« Reply #9 on: 12 January 2014, 13:05:23 »
sam
