Author Topic: Long nose plenum onto short nose....?  (Read 1802 times)
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
« on: 13 January 2014, 19:37:24 »
I got given the plenum off a longnose 3.2, I know it lines up and would bolt to the 2.5 shortnose I have in my elite but the dual ram system doesn't line up. Would it just be a case of getting some silicone hoses and connect them from the dual ram and onto the plenum... would there be an advantage maybe or would it reduce the power...?
D.I.L.L.I.G.A.F...
Re: Long nose plenum onto short nose....?
« Reply #1 on: 13 January 2014, 19:43:09 »
Not that straightforward...
You also need the following:
throttle cable from long nose 3.0.
both 90° pipe from either a 3.0 long nose or any 2.6/3.2
Then it will fit perfectly :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #2 on: 13 January 2014, 19:44:08 »
Plus, wasn't the long nosed plenum designed to create more power... thus swapping it would reduce efficiency?
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #3 on: 13 January 2014, 19:44:41 »
ignore that comment.... its the other way round. Back to school  :-[
RIP Paul Lovejoy
minifreek
  • Wigan
« Reply #4 on: 13 January 2014, 19:49:55 »
So its worth putting on then...?
Im sure I can get hold of a throttle cable froma scrappies and possibly the 90 bends too...
Thanks for the quick replies folks :)
D.I.L.L.I.G.A.F...
« Reply #5 on: 13 January 2014, 19:52:34 »
You`ll also need the Idle control valve air pipe and the multiram switch unit to throttle body air ducts.
« Reply #6 on: 13 January 2014, 20:06:49 »
Or 90° pipes if you can't remember their actual name ;D
