Author Topic: 2.5 TD with AR35 problem  (Read 3688 times)
Re: 2.5 TD with AR35 problem
« Reply #15 on: 14 January 2014, 15:50:54 »
Thanks again, yes I thought I'd seen a guide, I am still hoping not to have to do it. The worst thing for me nowadays is actually getting it up on stands. Once up, not a problem. I guess I need better jacks.
I really fancy one of those car lifts
Yep, join the queue. ;)
A mate of mine was given one when he took his Renault for a service at the local dealer. The workshop was being refurbed. I want one, but not badly enough to drive another Renault and have it dealer serviced. ;D
Omegatoy
  • UK
« Reply #16 on: 14 January 2014, 20:09:08 »
concur with others almost definetly selector switch gunged up,possible it was frozen as well from the damp inside it,
as regards getting car up in air,drive the rear wheels up on car ramps then jack the front one side at a time,using axle stand when high enough,easy and not to killing? :y
dazza88
  • luton (bedfordshire)
    • 2001 2.6 v6 auto omega
« Reply #17 on: 14 January 2014, 20:14:21 »
Yep had same prob cleaned the selector switch and was fine  :y good luck mate   :y
2002 2.2 cd auto             mrk2 astra gte
vauxhall colton               vauxhall omega 2.6 v6 auto
ford sierra saphire 20l   vauxhall omega 2.2 dti 02 plate
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #18 on: 14 January 2014, 22:30:49 »
Good idea, I'll try that next time. :y
Shackeng
  • Ramsbury
« Reply #19 on: 24 January 2014, 19:23:29 »
Well, having been with no broadband for a week, I didn't want to start on this without the guide. Got it up on stands today, (wish I had that lift) and having removed the selector switch, just as I was about to dismantle it I remembered the AR25 with a spare switch sitting under various other unwanted detritus in the corner of the garage. I've now swapped them over, and, while still on stands, all the lights now work OK, test drive to come.
Having decided that, while I've got it on stands, and thus easier to access almost everything, I would also fit poly bushes (ordered) to the front of the bones, and also sort a lazy drivers door lock and dubious rear pax window motor, I get a text from #1 son requesting garage use to change a spring. >:( >:( >:(. He'll have to help me put it back on stands again after we change the spring. Sods law, we changed the front hub on the same side last weekend, and the spring has broken since, so the same stuff has to come off again! :-X :-X :-X
Shackeng
  • Ramsbury
« Reply #20 on: 25 January 2014, 17:39:23 »
Just road tested it for 30 miles, no problems. I'll clean the other selector and keep it as a spare. :y
