Car lifts
Started by Shackeng, 14 January 2014, 18:40:55
Gaffers
Crazycarzowner
Always liked the idea of these but they're a bit pricey      http://www.smartgarageequipment.co.uk/1_post_lifts_home.html
Quote from: Jasonm on 16 January 2014, 01:00:13
£1650+vat for a four ton two post lift is pretty impressive, especially as that's delivered and installed 8)
I wonder if they're weather proof :-\
Gaffers
Quote from: Guffer on 24 January 2014, 09:46:23
I have the quote for the Autolift 3000.  Looks very reasonable although I wont be able to get one for a few months yet :-[
https://dl.dropboxusercontent.com/u/15206326/Price%20list%20incl.%20Freight%20ENG.pdf
https://dl.dropboxusercontent.com/u/15206326/EASYLIFT_EN.pdf
https://dl.dropboxusercontent.com/u/15206326/AUTOLIFT_EN.pdf
1st link seems a bit odd IMHO ... Autolift 3000 without the drill is MORE than it with the drill !!!  (top 2 rows of the quote !)  :)
Gaffers
I did see that, probably a typo but it's an official quote so...... ::)
Oh and Tax needs to be added as well :y
Shackeng
Quote from: Guffer on 24 January 2014, 09:57:58
I think I might get one of the 3000. :y
Gaffers
Quote from: Kevin Wood on 24 January 2014, 10:33:15
Can't help thinking the sill looks a bit buckled on the car in the photo.  :o :-\
Top right?  I think that is damage caused by pressure on the panel rather than from the lift... :-\
I would get two... one for each end :-\ really didn't like the lack of control when the chap tipped the car forward and back in the video... it came down quickly enough to do some damage... :-\
How strong is it laterally? If you're swinging on a front wishbone bolt, what's to stop it collapsing sideways, on your head :-\
Devils advocate and all... :y
Gaffers
Personally I wouldn't use it to tip kitty over from front to back.  Rather lift one end up at a time.  You dont f $#@ about when lifting 2.4 tonnes.
Quote from: Guffer on 24 January 2014, 11:49:20
Quite :y a tenth of that is enough to ruin your day...
Shackeng
My feeling is that it may work OK for lifting each end in turn, then fitting stands. Just an expensive, but easy to use, jack, really. I would not like to use it on the sills. :-\
