Car lifts
Started by Shackeng, 14 January 2014, 18:40:55
Shackeng
I like the look of this but can't find a price. http://www.cartaruk.com/products.html
Trouble is, lift will be in the way for all key jobs like ATF, exhaust ect  :-\
Shackeng
Trouble is, I can't really justify a fourpost lift. Has anyone on here experience of useful DIY lifts to take an Omega?
Varche
Quote from: Shackeng on 14 January 2014, 18:40:55
How about one of these in sixth picture down? Cost about £50 and doubles as garden seating if you put a table in the middle.!
http://www.omegaowners.com/forum/index.php?topic=45487.msg687020#msg687020
I like that. Any foundations needed?
chrisgixer
Might look a bit odd in Shaks drive though. ;D
chrisgixer
Micheldever have loads of these type things, dug into the floor.
http://zonda.e.tradeee.com/product_view/50384629/Scissor%20Car%20Lift.html
Won't be cheap though. :(
Varche
Quote from: tunnie on 14 January 2014, 20:45:35
Probably safer to lay a pad of concrete on some rammed hard core. I put 15 cm spacing wire rod mesh in mine.
Also works for MX5s, IIRC - or was it at the place in Murcia that I had to cable tie the undertray on? Can't remember. :-\
Suppose I should effect a permanent repair sometime. ;D
Shackeng
Quote from: joshwyatt on 14 January 2014, 22:13:24
I know someone that's got one of these, he uses it most weeks...
http://www.ebay.co.uk/itm/CAR-LIFT-MOBILE-SCISSOR-LIFT-GREAT-FOR-HOME-WORK-USE-/231135741539?pt=UK_Lifting_Moving_Equipment&hash=item35d0c38663#ht_6795wt_958
Thanks Josh, bit pricy tho' :-\ Where is the nice simple sturdy one designed for us DIY mechanics? :-\ :-\ :-\
serek
have one of those in my workshop
take up to 2.7 ton
you wont replace ATF or exhausts on RWD as area is limited
but for servicing and other repair do the job,
Seth
Quote from: chrisgixer on 14 January 2014, 20:54:51
Gaffers
Quote from: serek on 14 January 2014, 23:05:26
take up to 2.7 ton
I like that but the 2.7T capacity makes it very close to the kerb weight of Kitty :-\
Gaffers
