Author Topic: ENGINE PAINT  (Read 3967 times)
djhorner
  • isle of lewis
    • omega mv6
ENGINE PAINT
« on: 15 January 2014, 18:23:11 »
i'm needing some advice , i want to paint the heads on omega and the inlet manifold aswell but can't decide what colour would be best any ideas :y
martin42
Re: ENGINE PAINT
« Reply #1 on: 15 January 2014, 18:31:20 »
Silver  ;D
Re: ENGINE PAINT
« Reply #2 on: 15 January 2014, 18:50:24 »
Well to make it stand out , it has to be red/orange heads ... maybe black inlet  :-\
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: ENGINE PAINT
« Reply #3 on: 15 January 2014, 18:55:25 »
Who;s going to see the Inlet Manifold on a V6?  ;D
Re: ENGINE PAINT
« Reply #4 on: 15 January 2014, 18:57:04 »
just sand the plenum it will be original silver color..  for heads not sure but paint must be heat resistant or it will flake ..
Re: ENGINE PAINT
« Reply #5 on: 15 January 2014, 19:02:49 »
When you take it to bits  ;D
zirk
  • Epping Forest
Re: ENGINE PAINT
« Reply #6 on: 15 January 2014, 19:04:18 »
Acquired one of them on a 3.2, someone spent a lot of time and effort doing it, you can see your face on it.
zirk
  • Epping Forest
Re: ENGINE PAINT
« Reply #7 on: 15 January 2014, 19:07:27 »
Ah, right, so pull up, hey people like my painted Inlet Manifold, Oh, hang on, give me 10 mins, just need to whip the Plenum off, wait one.  ;D
Keith ABS
  • Maldon Essex
Re: ENGINE PAINT
« Reply #8 on: 15 January 2014, 19:17:30 »
  Its your car, your taste, but expect lots of ribbing if its too bright 8) 8) :o :o
Keith B
Re: ENGINE PAINT
« Reply #9 on: 15 January 2014, 19:19:51 »
done that ;D
but used dremel for initial sanding work.. so sanding by hand took less time..
« Last Edit: 15 January 2014, 19:22:23 by cem »
Re: ENGINE PAINT
« Reply #10 on: 15 January 2014, 19:24:57 »
Yellow high gloss for the plenum  :)
tigers_gonads
  • Online Online
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: ENGINE PAINT
« Reply #11 on: 15 January 2014, 19:26:29 »
What colour is the car body paintwork ?
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: ENGINE PAINT
« Reply #12 on: 15 January 2014, 19:59:01 »
Painting aluminium heads/plenums etc seems a waste of time to me. Buy some ally cleaner, and give them a good scrub/jet-wash.
I'd paint(or powder coat) brackets black.
If the engine is out of the car and stripped down, then I'd probably paint the block body colour, using the same 2 pack paint as on the bodywork itself.
djhorner
  • isle of lewis
    • omega mv6
Re: ENGINE PAINT
« Reply #13 on: 15 January 2014, 21:54:48 »
car its self is black was thinking red for inlet black for plenum and not sure for the heads
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: ENGINE PAINT
« Reply #14 on: 17 January 2014, 19:47:50 »
have a look at my engine in the gallery under rebuilding x30xe got the block, heads and plenum all powder coated candy red.
