Author Topic: AC Condenser  (Read 2503 times)
jonny2112
  • Bangor NI
    • 2.6 Elite
AC Condenser
« on: 15 January 2014, 21:07:11 »
As a matter of interest, are these the same across the range?
Or are they model or engine specific?
Re: AC Condenser
« Reply #1 on: 15 January 2014, 21:13:02 »
All the same :y
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: AC Condenser
« Reply #2 on: 15 January 2014, 21:19:59 »
Cheers Al, just as I thought  >:(
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: AC Condenser
« Reply #3 on: 15 January 2014, 21:35:00 »
Does this part number 52475899 make any sense?
Re: AC Condenser
« Reply #4 on: 15 January 2014, 21:52:41 »
According to my copy of the EPC ...
52475899  CONDENSER, ASSY., AIR CONDITIONING (NLS.- USE 52482789 )
so that is the "no longer stocked" item .. you need to buy the 52482789 item .. :)
HTH  :)
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: AC Condenser
« Reply #5 on: 15 January 2014, 22:20:55 »
Ah, cheers Nige  :y
That makes sense - found one at a low price but seller said it wouldn't suit my car. Didn't really understand why? So thank you.
Re: AC Condenser
« Reply #6 on: 15 January 2014, 22:38:35 »
Condenser knackered then Jon ???
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: AC Condenser
« Reply #7 on: 15 January 2014, 23:26:19 »
Yes mate it's leaking apparently  :(
I still have the link you gave me, but a new one is some way off atm. Saw a cheap one online and thought I'd check.
Re: AC Condenser
« Reply #8 on: 16 January 2014, 08:20:40 »
That part number should be fine, the fact its no longer serviced just means its been superseeded by a later number, the original number should still work and fit.
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: AC Condenser
« Reply #9 on: 16 January 2014, 09:15:39 »
Thanks Mark. At £75 ish I thought it might be worth stretching for, but the Vx retailer tells me that it is NOT suitable for my car, as the condensers are not the same across the range  :-X
Re: AC Condenser
« Reply #10 on: 16 January 2014, 09:40:03 »
Have had an early 3.0 one fitted to mine... had to modify either the bracket for the silver canister that mounts to it, or the casing of the nearside front fan iirc, so perhaps they are sort of right... the plumbing is unchanged though :y
Re: AC Condenser
« Reply #11 on: 16 January 2014, 09:44:18 »
My version of the EPC (admittedly quite old) gives differing part numbers for just 5 options
 1   CONDENSER, ASSY., AIR CONDITIONING (NLS.- USE 52482789 )    (52460418) (18 50 028) 1
  1  CONDENSER, ASSY., AIR CONDITIONING (NLS.- USE 52482789 )   -W1999999 (52475899) (18 50 047) 1
  1  CONDENSER, ASSY., AIR CONDITIONING  X1000001-  52482789 18 50 059 1
  1  CONDENSER, ASSY., AIR CONDITIONING RHD  Y25TD   52482789 18 50 059 1
  1  CONDENSER, ASSY., AIR CONDITIONING LHD  Y25TD   24461360 18 50 075
2 of which are NLS use 52482789
2 are use 52482789
and just ONE uses a different part number now .. and thats the LHD 2.5 TD
so unless you have a LHD 2.5 TD its all the same part numbers :)
[Assuming my EPC is correct]
HTH
Re: AC Condenser
« Reply #12 on: 16 January 2014, 09:57:30 »
Condenser coming off breaker this weekend ::)
Re: AC Condenser
« Reply #13 on: 16 January 2014, 11:01:26 »
Fancy that ;D
Re: AC Condenser
« Reply #14 on: 16 January 2014, 11:10:23 »
Page created in 0.017 seconds with 19 queries.
