It seems that ze germans have a sense of humour after all.
Started by Field Marshal Dr. Opti, 18 January 2014, 11:21:10
After decades of peasantry why shouldn't you have a few creature comforts :y
Quote from: Taxi Al on 19 January 2014, 11:22:05
I agree, Mr Al. :y
My wish is to one day be as wealthy as STMO......then perhaps I'll be able to afford my 'Dream Daewoo'
With dreams like that, who needs nightmares :o
Might I politely suggest an immediate dessistance from eating cheese with your Ovaltine Mr Opti :y
Quote from: Taxi Al on 19 January 2014, 13:25:08
I had this horrible dream that I was stranded in Wakefield when a passing Daewoo owner with dubious intent offered me assistance....... :( :( :(
It was scary. :o :o ;D ;D ;)
Taxi_Driver
#35
Quote from: Mr. Opti on 18 January 2014, 11:51:32
Quote from: Andy B on 18 January 2014, 11:47:17
Quote from: Mr. Opti on 18 January 2014, 11:39:11....
... and the service indicator reset.
there used to be a website with all the variants listed of how to reset the service message without Star. This is how mine is done .......
a) Turn ignition key to '1'
b) Press the lower system selection button (left hand edge of steering wheel) repeatedly until you have the Basic display with mileage or temperature in the display
c) Press the odometer reset button briefly 3 times and you see the voltage display on the cluster and a ping is heard
d) use the scroll down arrow button until you see the 'Service menu'
e) Use +/- buttons to select the menu item CONFIRMATION then press the lower system selection button to confirm ("Complete service" is highlighted in dispay)
f) Confirm full service by pressing lower system selection button
g) Press top system selection button until you get back to Service menu
h) Use +/- buttons to select the 'Special Work' menu and Press the lower system selection button to confirm
i) Use +/- buttons to select Service 3 & press lower system selection button to confirm
j) Use +/- buttons to select the oil grade you used & press lower system selection button to confirm (nb, where only 1 grade of oil is allowed, there wont be a selection available)
k) repeatedly press lower system selection button until out of service mode
I think they're mostly similar  :-\
Thanks, Andy. The service indicator is currently around the 4800 mile mark, so I can keep my money in my pocket for now. :y
PS.....I still haven't found the dipstick yet.
If that doesnt work Mr Opti.....have a looksey here
http://www.scribd.com/doc/25812578/March-2009-Mercedes-Benz-Reset-Service-Indicator-Guide
Page 7 is for the CLS  :y
Edit: Forgot to add.....some mercs are fussy......make sure your sitting comfortably with the drivers door shut......i jest not.....the newer shape E classes wont do anything unless drivers door is shut
Quote from: Taxi Driver on 19 January 2014, 19:04:36....
Not just Mercs.  A neighbour has a 7 Series BMW, and that's the same eg, it won't go into gear if the door is open ....  ??? ???
