It seems that ze germans have a sense of humour after all.
Started by Field Marshal Dr. Opti, 18 January 2014, 11:21:10
I had to laugh. :).......or perhaps cry. :'(
I enquired about the cost of an 'A' service for my CLS 500 at a Mercedes main dealer.
The 'A' service is the most basic service, and consists of no more than an oil and filter change and a brief inspection to see if the washer bottle needs topping up, or the wiper rubbers are split.......etc ...etc.
So parts needed are 8 litres of fully synthetic oil and a filter......and maybe another 10 minutes scratching their arse as they idly look around the car.
COST......£327.50. ;D ;D ;D ;D
A Mercedes independent, some twenty miles away, will do the exact same job for £140......which is more than enough.
martin42
I know what option i would go for,the d.i.y option  ;D
When labour is well over £100 an hour, it doesn't surprise me.
Quote from: The Mad mechanic on 18 January 2014, 11:27:42
Agreed......but if I go  the Mercedes Indie route I get a stamp in the book and the service indicator reset.
Bearing in mind that the car has FSH it may be worth the extra cost......for now.
£327 for an oil change is simply is taking the piss.
£140 the indie is asking, less so.
Quote from: Mr. Opti on 18 January 2014, 11:39:11....
... and the service indicator reset.
there used to be a website with all the variants listed of how to reset the service message without Star. This is how mine is done .......
a) Turn ignition key to '1'
b) Press the lower system selection button (left hand edge of steering wheel) repeatedly until you have the Basic display with mileage or temperature in the display
c) Press the odometer reset button briefly 3 times and you see the voltage display on the cluster and a ping is heard
d) use the scroll down arrow button until you see the 'Service menu'
e) Use +/- buttons to select the menu item CONFIRMATION then press the lower system selection button to confirm ("Complete service" is highlighted in dispay)
f) Confirm full service by pressing lower system selection button
g) Press top system selection button until you get back to Service menu
h) Use +/- buttons to select the 'Special Work' menu and Press the lower system selection button to confirm
i) Use +/- buttons to select Service 3 & press lower system selection button to confirm
j) Use +/- buttons to select the oil grade you used & press lower system selection button to confirm (nb, where only 1 grade of oil is allowed, there wont be a selection available)
k) repeatedly press lower system selection button until out of service mode
I think they're mostly similar  :-\
Quote from: Andy B on 18 January 2014, 11:47:17
Thanks, Andy. The service indicator is currently around the 4800 mile mark, so I can keep my money in my pocket for now. :y
PS.....I still haven't found the dipstick yet.
Quote from: Mr. Opti on 18 January 2014, 11:51:32...., so I can keep my money in my pocket for now. :y
or in the fuel tank  ::)
Quote from: Mr. Opti on 18 January 2014, 11:51:32PS.....I still haven't found the dipstick yet.
I don't think you have one  :-\ I think you check via the dash cluster  :-\  :-\
The Indy price isn't that bad really when you consider that there's £80 worth of oil at retail prices and you get the stamp.  ;)
Quote from: Andy B on 18 January 2014, 11:55:12
Yes......and if this goes 'tits up' what then? :-\
There seems to be no way to check the oil level manually. :-\
Quote from: Sir Tigger on 18 January 2014, 11:58:51
They tell me that they use either Mobil 1 0/40 or Shell helix 5/40.
Quote from: Mr. Opti on 18 January 2014, 12:12:33....
Nasty, expensive sounding noises from under the bonnet  ???  ???  ???
A quick Google shows that a proper dipstick is available ..... at a price .... no idea what else is necessary to fit it  :-\  :-\  :-\ One for MArk maybe  :-\
http://www.ebay.co.uk/itm/Mercedes-Engine-Oil-Dipstick-CLS500-CLS55-SL500-SLK55-S430-S500-/370759269386
Quote from: Mr. Opti on 18 January 2014, 12:19:08
Isn't GM's fully skimmed suitable?  :-\  :-\
I'd probably be inclined to get the back street stamp at the maximum service inteval (eg, 2yrs/20k), and do a diy every 5k/1yr.
When I thought my MV6 was still worth something (as my intention was not to keep it long), I used to get the cheapest Masterfit stamp annually, and squeeze in 3 DIYs between.
