Author Topic: Removal of upper gearbox bolts  (Read 1558 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 18 January 2014, 15:52:03 »
OE03 EWW 3.2 petrol manual saloon
Clutch replacement job. I am at the point where I wish to remove all the bellhousing bolts. There are three 19mm bolts at the top to which I have no access. Is it in order to lower the gearbox mounting to gain access to them?
chrisgixer
Re: Removal of upper gearbox bolts
« Reply #1 on: 18 January 2014, 15:54:25 »
There is access to reach up. Did Als easy enough.
martin42
« Reply #2 on: 18 January 2014, 16:01:00 »
Use the force terry,you can do it  ;D
  • Auckland
    • Mazda MPV
« Reply #3 on: 18 January 2014, 16:18:37 »
Long time ago now but I think I used 3 wobble bar extensions draped across the bellhousing to reach the socket from underneath the car.
chrisgixer
« Reply #4 on: 18 January 2014, 16:22:39 »
Yes sorry that wasn't very helpful.
As Andy says, withe extensions, and reaching up for a hug. Its tight, but doable. :)
  • Auckland
    • Mazda MPV
« Reply #5 on: 18 January 2014, 16:48:16 »
Simple answer - yes (but check that the engine doesn't lean too far back & strain hoses and electrickery)
With the downpipes still attached it probably won't help much though because the exhaust system will prevent the engine from moving far.
terry paget
    • 3 Astras 2 Vectra
« Reply #6 on: 18 January 2014, 17:11:42 »
Exhaust is removed. I can feel two (19mm?) bolts heads, the third seems to be near the oil cooler pipes. Thanks to all for advice, I will try again.
« Reply #7 on: 18 January 2014, 18:04:46 »
They might be 17's, but otherwise as above :y
