Discovery TD5
Started by Martin_1962, 18 January 2014, 20:23:57
the alarming man
it is poor maintenance vamps if the seals are kept clean and drain holes are clear they won't leak.. the problem is once they start to leak replacement is the only cure and they are PITA to do:y
hotel21
#16
Quote from: the alarming man on 20 January 2014, 18:41:14
You talking sunroof?  Its not the glass to sunroof rubber seal that leaks most of the time.   Problems include (but not limited to) drains and the plastic 'squares' where drains attach to lower cassette assembly but mainly leak where upper and lower cassette portions sandwich the metal roof skin.  The 'seal' is ineffectual at best (thin foam sponge type stuff) that deteriorates over time and allows water to pass and create leaks through winder handle/leccy motor control assembly.
Best repair is removal of upper and lower portions and clean off old guff then reseal with RTV silicone top and bottom.  :y
the alarming man
correct I am talking sunroof. The seal is only ineffectual due to the not being looked after and it as nothing to do with the lump of glass at all...poor maintenance not cleaning the drainage channels and keeping the drain clear
but as for sealing sunroof that is not a repair at all it is a cop out and a quick fix which doesn't solve the problem all it does do it means you have a sunroof you cannot use
I still come out in a cold sweat when I see a Land Rover badge, scarred for life! ;D ;D ;D ;D :D :y
Quote from: Marks DTM Calib on 20 January 2014, 22:12:23
I have had and loved a few series Land Rovers, not exactly luxury but functional, do you know that you can get 22 Cub Scouts into the back of a LWB model...... :y :y In the old days.... :-X
Martin_1962
Quote from: Vamps on 20 January 2014, 22:49:40
Should be able to squish mad BMWs with one though and hopefully repel low flying Peugeots, will be interesting to see how much compensation I get
henryd
Quote from: the alarming man on 20 January 2014, 22:10:04
H21 is not saying seal up the roofs themselves,they mainly leak where the cassette joins to the roof panel,that is what needs sealing up(on the D2 anyway)
other rides
I have to look after and maintain
1 off Series 3 short wheel base pickup - 2.25 petrol
1 off series 4 long wheel base with bench seats in rear - 2.25 petrol
1 off 110 long wheel base with cherry picker mounted on rear, 2.5D
1 off 110 long wheel base with road rail fittings - 300TDi
1 off 110 long wheel base - 2.5TD (19J engine)
There is also a series 1 petrol short wheel base with a rotted head (but dry stored for the last 20 plus years, which I am not going bloody near!
And I bloody hate working on them, there is always 'something' needs doing on the dam things.
Just like an Omega then... ;D
Quote from: Taxi Al on 21 January 2014, 08:49:42
No, they require SO MUCH more fiddling with!
hotel21
Quote from: henryd on 21 January 2014, 08:16:48
Correct. The sunroof has 4 major components viz outer plastic part that's stuck to outside of roof, inside plastic part that has the drain tubes, operating mechanism etc coming from as well as the rubber seal that the moving glass panel seals against. The seal I refer to is the one fitted between the outer plastic housing and the outer metal roof skin and the inner plastic panel (with drains etc) that seals against the inner roof skin. Removal and reseating requires removal of interior side panels and roof liner before both sunroofs can be split and removed and resealed.
Once done, 99% of leaks are sorted and glass panel remains fully functional.
It's not poor maintenance it's poor design and manufacturing.  :y
bigboykarl
what sort of mpg does a td5 achieve...at the min i have a e320cdi which averages 30mpg around town and 40 ish at 85 on the motorway
This sums things up nicely
http://www.repairmylandrover.co.uk/featured-items/alternative-land-rover-owners-manual
One of my favourites:
A note about Landrover horns. It may not be possible to hear the horn sounding whilst driving your vehicle as we fitted the quietist one we could find, that is because Landrover Plc do not wish to contribute to sound pollution. This horn works by giving a small, none damaging, electric shock to an ant that lives in metal box on the front grill, this causes the said critter to fart through a small trumpet, we think. Sh*t if you can't hear a Landrover heading towards in the first place you are as deaf as a post so sounding the horn is a useless exercise anyway... The sound deadening we omitted to fit to your vehicle also helps prevent you hearing the horn above the cacophony of mechanical noise that emanate from your vehicle during normal use
henryd
Quote from: bigboykarl on 24 January 2014, 10:42:01
Thats a distant dream for any Discovery 2 :-\
other rides
henryd
Quote from: Marks DTM Calib on 24 January 2014, 12:57:18
Lol ;D ;D
other rides
