Discovery TD5
Started by Martin_1962, 18 January 2014, 20:23:57
Quote from: Marks DTM Calib on 24 January 2014, 12:57:18
This sums things up nicely
http://www.repairmylandrover.co.uk/featured-items/alternative-land-rover-owners-manual
One of my favourites:
A note about Landrover horns. It may not be possible to hear the horn sounding whilst driving your vehicle as we fitted the quietist one we could find, that is because Landrover Plc do not wish to contribute to sound pollution. This horn works by giving a small, none damaging, electric shock to an ant that lives in metal box on the front grill, this causes the said critter to fart through a small trumpet, we think. Sh*t if you can't hear a Landrover heading towards in the first place you are as deaf as a post so sounding the horn is a useless exercise anyway... The sound deadening we omitted to fit to your vehicle also helps prevent you hearing the horn above the cacophony of mechanical noise that emanate from your vehicle during normal use
PMSL.
Still, still beats a Yamaha horn. It was so bad, I replaced it, only to discover the new one was even quieter ;D
joff
Wife is on her second TD5 and this one is one of the first 99T reg, it now has over 205K on it. 10P engine code
EGR removed
De-cat
Removed centre box (not chipped yet) and pulls like a train 30mpg all day long. Poly bushed all over. :y
I have two spare engines in the garage, a 10P in bits almost at point of rebuild and a 15P with normal head issue (no4 injector hole leaking fuel past it which is a £150 to have welded and re-cut) to start work on this summer.
Martin_1962
Quote from: joff on 26 January 2014, 01:40:13
EGR removed
De-cat
75000 on a ten year old one.
The switch placement is very random.
Lights are only halogen, not so nice after Xenons
Quote from: Martin Imber on 26 January 2014, 10:16:43
Check the connections to the chassis are good, they sometimes get a bit of corrosion, increasing resistance.
