Author Topic: Some more bits  (Read 3923 times)
Some more bits
« on: 18 January 2014, 20:51:13 »
Breaker will be going in the next few days so I`ll condense everything into one thread then. :y
Working non leaking AC compressor £30 posted
2.6/3.2 steering pump £25 posted
Genuine known good coilpacks (n/s has small split at end of one rubber boot) £25ea posted, £40pr posted.
Known good autobox selector switch £25 posted
Rear vented calipers £20ea posted, £30pr posted
In tank fuel pump £20 posted
Will post pics tomorrow.
amba
  • Medway towns
    • German V6
Re: Some more bits
« Reply #1 on: 18 January 2014, 21:43:12 »
Sorry its not a big order Rob,but could do with :
4 bolts from the oil cooler plate.
Plug and about 150mm of the loom from throttle body connector.
Cheers
Andy :y
amba
  • Medway towns
    • German V6
Re: Some more bits
« Reply #2 on: 18 January 2014, 21:55:41 »
Plug and about 150mm of the loom from throttle body connector...TPS plug :y
Re: Some more bits
« Reply #3 on: 18 January 2014, 23:19:46 »
Cheers
Andy :y
Engine prov. sold Andrew, so no bolts mate
amba
  • Medway towns
    • German V6
Re: Some more bits
« Reply #4 on: 19 January 2014, 08:08:11 »
Cheers Rob.
Any luck with plug and part loom then ? :y
Re: Some more bits
« Reply #5 on: 19 January 2014, 09:17:07 »
Cheers Rob.
Just waiting to hear from prospective buyer of engine as to whether they need the loom as well Andrew
kevinp58
  • kent
    • 2002 3.2 elite
Re: Some more bits
« Reply #6 on: 19 January 2014, 15:39:09 »
sent a PM about the coil packs.  :y
Re: Some more bits
« Reply #7 on: 19 January 2014, 15:47:17 »
Replied :)
kevinp58
  • kent
    • 2002 3.2 elite
Re: Some more bits
« Reply #8 on: 19 January 2014, 16:22:43 »
Replied :)
 Thanks and replied back.  :)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Some more bits
« Reply #9 on: 19 January 2014, 17:12:37 »
Cheers
Andy :y
Amba, assuming I haven't binned it, I may have an old plate and the bolts tucked away somewhere, if you get stuck, guessing there M5 or similar, could you confirm the right size?
As for the Loom, would the 3.0 be the same as the 3.2?,   :-\
Re: Some more bits
« Reply #10 on: 19 January 2014, 17:21:22 »
Coilpacks, fuel pump, rear calipers, SOLD
