Author Topic: P0115  (Read 1280 times)
P0115
« on: 19 January 2014, 18:06:18 »
Following on from the codes I had previously, I have swapped the ecu coolant sensor plug with the purge valve one...
Codes rechecked and still have an 0115 :-\
Would it be reasonable to assume the temp sensor is toast?
It is most definitely plugged in correctly and securely :y
Where best to buy one from?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: P0115
« Reply #1 on: 19 January 2014, 18:48:36 »
Got my last one from GM think it was £15 there abouts on TC :)
Hoof'land storeman.
Re: P0115
« Reply #2 on: 19 January 2014, 18:51:10 »
No point messing with mickey mouse ones then :y
biggriffin
Re: P0115
« Reply #3 on: 19 January 2014, 19:05:26 »
Think the difference was couple quids, so yes go genuine for reliability and piece o mind :y
Hoof'land storeman.
Re: P0115
« Reply #4 on: 20 January 2014, 19:38:22 »
£17 later, and all sorted. Apparently they don't respond too well having 12v put across them ::)
The net result being that the ecu thought that the coolant temp was -30°. Started fine with fuse 18 removed, but as soon as you refitted the fuse it simply flooded it. :-\
Pic of P/N and plug in the test zone for future reference  :y
Re: P0115
« Reply #5 on: 22 January 2014, 00:37:10 »
Coincidentally the aircon now works as advertised, via the relay rather than a two inch long wire with a spade terminal each end ::)
