Dangleberries!! Part 2
Started by Sir Tigger KC, 21 January 2014, 22:17:30
So my nice shiny reconditioned alternator turned up today!  :) but what a complete PITFA changing it is!!  ::)  :(
I thought the bottom bolt was awkward enough but the top bolt is a nightmare!!!  :o The B-Bolt is a walk in the park in comparison!!  :-\
After removing the air intake assembly, I managed to snap off one of the mounting bolts on the cruise control box, which is a disaster as the LPG vapouriser bracket was mounted on that as well, so I guess I'll have to drill through the wheel arch for a new bolt.  :-\
I finally removed the old alternator and while connecting the new one I think I over tightened the positive lead (chunky one) as there was a slight cracking noise.....  :-\  The problem was that I couldn't get a spanner on it as the connection is slightly recessed so I used a socket and I'm ham fisted!  :-[  I hope to hell I haven't buggered it as I can't face going through it all again!!  :'(
I gave up this evening when I was going to drill a hole through the wheelarch for the cruise bolt and my drill died on me!  >:(
Not my day!!!  ::)
When I'm as rich as Opti the first thing I'm going to do is go out and buy a Daewoo!!!  ::)  ;D ;D
jonny2112
Oh dear  :-\
Hopefully 'all's well that ends well'  :y
Webby the Bear
Sorry to hear about your problems ST  :'(
What have and haven't you removed to get to it? I took bagpipes out, aux belt off, sai shite out the way, aux tensioner off. . . And then there was bags of room to get to the bolts.
Hth
RIP Paul Lovejoy
jonny2112
Quote from: Webby the Bear on 21 January 2014, 22:26:26
Hth
That'll be handy if / when I need to do mine  ;D
Hth
That would have made life easier....  :-[
Webby the Bear
I have no idea if the guide says to do it that way..  . . . However I'm now a veteran of removing everything up front following the cam belt implosion  ::)
11mm on the back and undo from the front. Knock bolt through. Then undo connections.
Just make sure you don't pinch knock wire sensor after alternator is replaced  :y
RIP Paul Lovejoy
I got a socket with a knuckle joint on the top knut....... eventually!  ::)  :)
Talk about awkward though!  :(
Quote from: Sir Tigger on 21 January 2014, 22:17:30
Not my day!!!  ::)
Tigger I admire you..  even in that mess you have your sense of humour..
[cant use emoticons as I cant see any of them now]
Quote from: cem on 22 January 2014, 09:24:56
Not my day!!!  ::)
Its all part and parcel of Mig ownership  :P Get down and dirty with the spanners . Better than working on a pug  >:(
Quote from: Emd on 22 January 2014, 15:28:25
Not my day!!!  ::)
You can't kid us, Mr Emd......you miss that Pug and would buy it back at any cost. ;D ;D
Keith ABS
  You want to try doing one on a 2.5TD.Unbelivable
Keith B
All done, back together and all lights that should go out do.  :y  It's showing a very healthy charge on the meter as well, so alls well that ends well!  :)
I guess it's character forming.....  :-\
Rods2
Quote from: Sir Tigger on 22 January 2014, 17:28:34
Should provide plenty of holiday spending money, when you empty the swear box.  ::) :P ;D ;D ;D
Webby the Bear
Well done ST. Take a pic of your work and have a few beers whilst admiring aforementioned pic  ;D
RIP Paul Lovejoy
QuoteYou can't kid us, Mr Emd......you miss that Pug and would buy it back at any cost. ;D ;D
It went to a good home  ::)
