Author Topic: can I use this for ATF ?  (Read 1253 times)
SMD
  • London
    • :( nowt
chrisgixer
Re: can I use this for ATF ?
« Reply #1 on: 22 January 2014, 18:15:10 »
Head looks abit deep. Might be awkward depending on if the transmission tunnel is in the way.
Some sprayers I've used, the ATF has eaten the seals, even after cleaning. But worked in first use at least.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #2 on: 22 January 2014, 18:19:31 »
I used this.
http://www.powertoolsdirect.com/cuprinol-manual-pump-fence-sprayer?utm_source=google&kwd=&utm_medium=merchant_pla&gclid=CIKmw6qykrwCFYWWtAodD00AYQ
Whilst a few quid more than your link it works PERFECTLY with no awkwardness at all! Tube fits right in and there's room for litres and litres of ATF. You can also do your pumping whilst not being under the car as the tubing is very long. Pump is also very strong :y
RIP Paul Lovejoy
SMD
  • London
    • :( nowt
« Reply #3 on: 22 January 2014, 19:11:17 »
Webby the Bear
  • Northampton
« Reply #4 on: 22 January 2014, 19:15:11 »
That'll work. Good find!  :y
RIP Paul Lovejoy
