Sisters Zafira running shite
Started by tigers_gonads, 23 January 2014, 11:31:40
tigers_gonads
As above
1.7 dti on a 60 plate with 30,000 miles on the clock (ex mobility car)
Starts first time okay
Idles okay.
Increase the revs and it misses like a ba***rd until it reaches 2000 rpm then everything dandy.
This is intermittent.  Some days it runs great, others its cr*p
I have checked the bleed off pipes and the injectors for leaks but everything seems okay.
No codes or warning lights whatsoever.
If it was a petrol, i'd be pulling the plugs / leads / coilpack apart but it being a diesel  :-\ :-\
Are the injectors plug and play so to speak or do they need programing ?
I'm thinking along the lines of crap in / sticky injector  :-\
Anybody else think the same ?
I've told the brother in law to run some injector cleaner threw it in the meantime  :y
zirk
hoofing it
Give it an Italian tune up (2nd gear and red line it briefly) the DPF will be needing a good clean out.
Short runs kill diesels you need to get the cat/dpf hot to clean them out.
tigers_gonads
Sorry lads, been at the hospital over the last few days so not been around  :(
Zirk .... no codes or lights as far as I know (not tried my laptop on it yet).
Hoofing it ..... agree with you bud and have passed it on the brother in law  :y
Quote from: tigers_gonads on 27 January 2014, 11:57:44
Hope everthing ok mate  :(
tigers_gonads
Quote from: Emd on 27 January 2014, 15:06:32
Swmbo's mother  :(
She fell and broke her arm back in December during the high winds.
I'll pm yeh later bud  :)
