Insignia Q
Started by 05omegav6, 23 January 2014, 17:13:05
Does the Insignia have an analogue speed signal?
If so where might it be located?
TIA, Al :y
Auto Addict
Yes, on the speedometer :y
I like red cars
Quote from: Auto Addict on 23 January 2014, 17:29:17
8)
Any idea which pin and on which plug :-\
Auto Addict
I like red cars
Quote from: Auto Addict on 23 January 2014, 17:41:50
Quote from: Taxi Al on 23 January 2014, 17:35:26
8)
Correct ::)
A touch ambiguous :-\
If I pop the cluster out, which wire do I tap into?
I wouldn't mind guessing there is only CAN on the connector. Obviously at some point in the speedo, that gets converted.
That has been suggested to be the case :-\ needed to drive a taxi meter, if I need to buy a box, so be it, hoping to avoid if at all possible :y
Quote from: Taxi Al on 23 January 2014, 18:32:24
Veccy-C only has CAN, can't see Insignia being different
Quote from: TheBoy on 23 January 2014, 18:42:02
Not true :y has an analogue line but damned if I know what it connects ::) three BlRt wires near the heater motor, one of which is definitely analoge
Quote from: Taxi Al on 23 January 2014, 18:48:19
Did it change on later ones? As the half-CANs would have analogue for the HUs, for SDVC. Later Vecs had the full CAN HUs, so that analogue wouldn't be required.
All 4 Vec Cs I've dealt with have had one, 3x '55 facelifts and one '58... :y
Have been advised a box is needed, but would prefer to fit the wiring myself...( Not that I'm precious about my cars or anything :D). ..if at all possible :-\
Can pm reg if it helps :-\
Quote from: Taxi Al on 23 January 2014, 19:04:03
It wouldn't. :(
Can't think what a late vec-c would need analogue speed for, unless its a hangover from the half-can days
VIN :-\
The Vecs were two Design models, one Exclusive and one Life... So no consistent reason I can think of either ;D
Quote from: Taxi Al on 23 January 2014, 19:09:03
VIN :-\
The wiring diags are generic, not filtered for a specific config/spec.  Not that I currently have access to Insignia Schems, as I'm, as usual, laying in the bath...
