Author Topic: cooling fan  (Read 3721 times)
Bob G
  • Gloucester
cooling fan
« on: 24 January 2014, 12:28:31 »
even in this cold weather as soon as I start the engine the cooing fan comes on, ideas please.
Re: cooling fan
« Reply #1 on: 24 January 2014, 12:29:52 »
Aircon on?
omegod
  • liverpool
    • 2017 Seat Ateca
Re: cooling fan
« Reply #2 on: 24 January 2014, 13:16:51 »
If it's on all the time could be a duff fan switch, there are two in the rad,was that on mine anyway !
Bob G
  • Gloucester
Re: cooling fan
« Reply #3 on: 24 January 2014, 18:05:07 »
Yes on all the time from cold, aircon fan is ok comes and goes as it should, where are fan switches?
Re: cooling fan
« Reply #4 on: 24 January 2014, 18:06:10 »
Below top hose on pax side of the radiator :y
Bob G
  • Gloucester
Re: cooling fan
« Reply #5 on: 24 January 2014, 18:16:21 »
Thank you :)
2woody
  • Northumberland
Re: cooling fan
« Reply #6 on: 24 January 2014, 18:53:51 »
I think aircon forces the fan on all the time.
it may be worth a go with the aircon turned off
Re: cooling fan
« Reply #7 on: 24 January 2014, 19:17:20 »
Certainly puts the fronts on permanently....
Bob G
  • Gloucester
Re: cooling fan
« Reply #8 on: 25 January 2014, 22:58:25 »
should not trip the cooling fan though should it? sure it never used to used, but will give that a try and see what happens, just tried it and it does, very strange, totally confused now as sure it only used to kick in when engine hot
Re: cooling fan
« Reply #9 on: 26 January 2014, 00:11:49 »
Always runs when AC is on. Will increase to max speed when engine is hot
Bob G
  • Gloucester
Re: cooling fan
« Reply #10 on: 26 January 2014, 21:52:34 »
Thank you very much for the replies think fully understand it now :y :y
