Parrot Q
Started by 05omegav6, 24 January 2014, 17:59:27
Been thinking... ::)
Car has a CD400 fitted.
Having a plug and play DAB module fitted which intercepts the loom between the car and HU.
If I get a Parrot kit, MK9100 iirc, this requires an SOT lead to connect to the car loom.
Two questions:
1. Presumably it will need to be fitted between the car loom and the DAB unit to work properly?
2. Will this cause any operational issues?
Ta :y
I_want_an_Omega
IIRC, the 3100 has two outputs, one being a speaker level that would be used to switch through a vehicles existing speaker. The other is a line level output - have used these to feed into the input of a CCRT700, "selected" via the mute connection .......
Can bus... If only it were that straight forward :-\
blackviper90210
Not sure of the difference between the Parrot 9100 and 9200 that I have fitted.
Using just the SOT leads I've fitted this to a veccy c with full canbus and BOSE set up with no issues and now my 03 mig elite with no issues. :y
AKA - Mr Bracket
Quote from: blackviper90210 on 24 January 2014, 19:18:38
DAB is plug and play with SOT leads to radio. Parrot is plug and play as well, again with SOT leads.
The question is...
Can I daisy chain the Parrot to the DAB module to the HU without causing a problem?
Parrot would have to be closest to the speakers
Assuming both units drive the speakers themselves
If both are feeding in to aux it (cd400 has a decent aux in iirc), then you are going to have fun and games.
There is a bluetooth personality for that car that works quite well. Not sure how easy to retrofit, as GM make retrofits a pig
Quote from: TheBoy on 24 January 2014, 19:28:49
Any idea of the parts required :-\
Quote from: Taxi Al on 25 January 2014, 22:55:02
Sorry, no. I believe its just a simple module, but then has to be programmed into the car by GM (as per all Astra-J/Insignia options).
I have used an Insignia with Bluetooth module with my old gayPhone 3GS, and it worked really well. Not tried against a gayPhone 5/Siri enabled one, but can do, as its the Insignia I took to France in 2012, and the chap still has the car :)
Are you trying to say I need an  iphone on top of everthing else :o
Quote from: Taxi Al on 26 January 2014, 18:52:28
Sorry, confuddled you with someone else, I know you're an Android boy. Sony Ericsson IIRC?
A lot of these vehicle kits can be a bit fussy with phone device type, esp for voice dialling and contact syncing. No idea how the Insigina BT module copes with various Andriod devices, as its owner uses a gayPhone as well.
Yup, little green robot, me ;D
Will ask sis in law, think she had Bluetooth in her last Astra J  :-\
Further digging has suggested using a Parrot CK3000 Evolution with Parrot Multican, allowing total phone control using car controls alone, and binning the CK3000 controller, but not sure how upto date the Parrot site is, as the compatibility list is quite short when it comes to the Xperia Z1... :-\
And all because I went to collect a Crank Sensor ::)
break all compatibility info Insignia Vs. Multican >:( so have a suitable SOT lead and a MKi9200 on their way along with a canbus interface to drive the taxi meter...
Just need to figure out how to pull the dash apart now ::)
