Author Topic: Replacement springs for Elite  (Read 3558 times)
  • Auckland
    • Mazda MPV
« on: 26 January 2014, 10:06:35 »
As above really.
Not interested in changing the ride, I just want to replace the broken rear spring on my 2003 Elite saloon. It has self levelling suspension & I will be changing them as a pair.
Last time I looked genuine springs were astonishingly expensive. Is there a current 'best buy' for replacements?
chrisgixer
Re: Replacement springs for Elite
« Reply #1 on: 26 January 2014, 10:39:48 »
Only other "known" supplier of self levelling rear springs is kyb. Presume they still supply? (But if you find another supplier do shout. :) )
However some members have reported they rust very quickly. Which I guess might lead to early breakages.
Trade club helps considerably with gm springs, last I looked anyway.
chrisgixer
« Reply #2 on: 26 January 2014, 10:40:55 »
On cost grounds, I guess you know rear self levelling shocks will work with ANY springs...?
  • Auckland
    • Mazda MPV
« Reply #3 on: 26 January 2014, 11:11:14 »
Thanks Chris
Trying to find springs in the tradeclub site but none listed :-\
  • Auckland
    • Mazda MPV
« Reply #4 on: 26 January 2014, 11:30:51 »
Eurocarparts list Sachs, Anschler and BOGE springs for a 2.6 but can't be bothered to say whether for saloon/estate/self levelling ::)
Allgerman don't list any springs for the Omega. If I knew what make to go for I would give Jason a call & ask him for a quote.
  • Auckland
    • Mazda MPV
« Reply #5 on: 26 January 2014, 11:39:16 »
There were times when I thought the rear of the car was sitting a little too high, I don't know if the springs currently fitted are the correct spec, I suspect they may be pattern replacements :-\
I am fairly relaxed about what goes back on but I know that a little bit of homework now will save me paying over the odds or jacking up the rear (or both)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #6 on: 26 January 2014, 11:51:14 »
Sorry if this appears twice my computer is messing about. I fitted KYB springs they were a fraction of the cost of GM If you are worried about rusting you could treat them prior to fitting. The ones I fitted looked like they were powder coated so should last I would have thought
amba
  • Medway towns
    • German V6
« Reply #7 on: 26 January 2014, 11:57:24 »
RJ6227
If you do a google search under above KYB part number you should find a supplier,as that is what I replaced mine with few years back.From memory cots around £40 per spring. :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #8 on: 26 January 2014, 12:18:51 »
£40.00 per spring sounds high I think I paid that for a pair.
chrisgixer
« Reply #9 on: 26 January 2014, 12:21:00 »
I wonder would that plastidip be suitable :-\
chrisgixer
« Reply #10 on: 26 January 2014, 12:22:12 »
I paid £90 a pair delivered, a couple of years ago. Iirc
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #11 on: 26 January 2014, 12:27:01 »
Found the paper work My Kybs cost £57.00 in 2011 I had them fitted at a garage for £76.00. So £40.00 each could be about right now.
  • Auckland
    • Mazda MPV
« Reply #12 on: 26 January 2014, 12:32:12 »
ZF appear to be the parent company for Sachs, BOGE and Lemforder. I have just discovered their parts catalogue
webcat.zf.com.
They list a BOGE part number for self levelling (25-E49-0) "to be discontinued". A shame because I think they have the tapered ends the original springs would have had.
Right, KYB it is then. Thanks amba :y
« Reply #13 on: 26 January 2014, 13:19:24 »
When I first got TBE, I fitted Boge SL springs, which I used for about a year without issue (std Elite handling aside).
I would recommend above KYB, which seem to rust quite quickly.
  • Auckland
    • Mazda MPV
« Reply #14 on: 28 January 2014, 20:44:52 »
Phoned Jason at www.allgermanparts.co.uk.
While I was still on the phone Jason called BOGE and confirmed that they have discontinued the self levelling springs (boo  :() but they had one pair left (yay  :)).
Should be arriving on Thursday  :y
