Author Topic: Removing fuel rail and inlet.  (Read 2007 times)
Vauxhalloofer
  • South East
    • Cdx 2.2
« on: 27 January 2014, 17:39:07 »
Hi peeps, whats the procedure for removing the fuel pipes on the fuel rail also theres one black tube with a nut that leads to master cylinder.Is it ok just to pull the injectors out with rail as need to get inlet manifold off as full of oil,2.2 cdx.Thanks
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Removing fuel rail and inlet.
« Reply #1 on: 27 January 2014, 18:23:47 »
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #2 on: 27 January 2014, 18:24:19 »
Oops, sorry mine was for V6  :-[
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #4 on: 27 January 2014, 18:25:29 »
Yup, quick to type, slow to understand  ::)
RIP Paul Lovejoy
Vauxhalloofer
  • South East
    • Cdx 2.2
« Reply #5 on: 27 January 2014, 19:18:35 »
LOl whats that pipe thats on the left side of the inlet manifold black one .Is there a need to depressure fuel rail  :-\
symes
  • oxford
    • R reg 940 volvo
« Reply #6 on: 27 January 2014, 20:31:10 »
yes-unless you want fuel spraying everywere--little valve under black plastic cover on top of rail-iirc
Vauxhalloofer
  • South East
    • Cdx 2.2
« Reply #7 on: 27 January 2014, 20:36:24 »
Cheers, and the other pipe is it ok to disconnect that,is it some sort of vacuum pipe to master slave cylinder.
symes
  • oxford
    • R reg 940 volvo
« Reply #8 on: 27 January 2014, 20:37:49 »
yes thats fine-you need 17+19mm spanners for that-ok
Vauxhalloofer
  • South East
    • Cdx 2.2
« Reply #9 on: 27 January 2014, 21:04:14 »
Nice one, almost there its too good a motor to let it go.Is it ok to put injector rail back in or does it have seal of some type. :)
symes
  • oxford
    • R reg 940 volvo
« Reply #10 on: 27 January 2014, 21:12:56 »
each injecor has a rubber O ring-with care can be refitted but tbh have known them to split -well on v6 anyway
Vauxhalloofer
  • South East
    • Cdx 2.2
« Reply #11 on: 27 January 2014, 21:18:52 »
Thanks gotta take inlet off as quite a bit of oil in there.Also the cambelt tensioner pulleys were done a year ago do you think its ok to reuse the same cambelt tensioner,its gates so good quality.
symes
  • oxford
    • R reg 940 volvo
« Reply #12 on: 27 January 2014, 21:30:46 »
honestly mate I would do belt and tensioner and waterpump as well-check on some old threads on cam belts and 2.2 you will see what I mean mate
