Author Topic: Would these wheels fit facelift mv6 estate  (Read 1512 times)
idwal
  • telscombe cliffs near brighton
    • Mv6 estate (2000) Lpg
« on: 28 January 2014, 22:23:49 »
Am looking at a set of wheels.
2x 8,5x17 ET 30 235/45 R17
2x 9,5x17 ET 30 255/40 R17
Would these fit straight on or would I need spacers?
Any advice would be great :y
Thanks
Ken
MV6Matt
  • London
    • No car since 2022....
Re: Would these wheels fit facelift mv6 estate
« Reply #1 on: 29 January 2014, 20:38:01 »
Not sure that front wheels (presumably the 8J) would work with that ET - technically the Omega ET range is 33-39, Spacers might work.
Rears on a 9 wont be a problem I don't think but 255 with that side wall will put the speedo out a bit
Presumably Pcd is 110 and Centre Bore 65.1?
Pictures? Alloy manufacturer?
(thanks Ian)
idwal
« Reply #2 on: 29 January 2014, 22:31:29 »
Wheels are from Germany ebay 380822516398
Supposed to be from omega
« Reply #3 on: 30 January 2014, 00:49:45 »
Theses?
http://www.ebay.de/itm/380822516398?ru=http%3A%2F%2Fwww.ebay.de%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D380822516398%26_rdc%3D1
Rears will fit... fronts will bolt on but will likely foul the wheel arch/liner under load and on full lock, might also rub on the strut, depending on camber/tyres :-\
ET30 is fine noting above :y standard 17"s are ET33 and the official Omega Irmscher Sportstars are ET30 as well :y
Profile differences won't make much difference to the speedo against standard as the ABS produces the speedo reading as an average of alll four wheel speeds, stock 17"s run 235/45/17 tyres anyway :y
