Author Topic: ethernet splitter  (Read 3612 times)
pauls
  • By the sea minehead
    • Bmw x3
ethernet splitter
« on: 29 January 2014, 21:29:09 »
Could somebody recomend a 1 in 2 out splitter. I have tried a couple of the cheep plastic ones and no good. so i dont want to waste anymore money.
Re: ethernet splitter
« Reply #1 on: 29 January 2014, 21:32:42 »
You can't simply split ethernet
  • Auckland
    • Mazda MPV
« Reply #2 on: 29 January 2014, 21:38:35 »
This will do what you asked - problem is that your description sounds more like an adsl filter.
pauls
    • Bmw x3
« Reply #3 on: 29 January 2014, 21:50:49 »
Sorry not enough details..Due to my wifi and my laptop being crap i have ran a ethernet cable from my main computer into my man cave.I wanted it to run my laptop and my ps3. This will only be one at a time. but rather than having to keep unplugging it and swapping it over i thought i would get a splitter. They is loads on gaybay .
  • Auckland
    • Mazda MPV
« Reply #4 on: 29 January 2014, 22:48:04 »
OK
My previous advice still stands. £20 for a Netgear FS105 (pictured).
As Marks DTM Calib pointed out the Ethernet standard doesn't support passive splitters so either keep plugging one in at a time or use a network hub.
Ever Ready
  • Scotland
    • 2.2 CD Auto, Pug 308Hdi
« Reply #5 on: 29 January 2014, 23:14:40 »
 Below is a link to the same model as Andy H has only now it does Gigabit as well .  Less than £20 delivered
http://www.ebay.co.uk/itm/NETGEAR-ProSafe-GS105-5-Port-10-100-1000Mbps-Desktop-Ethernet-Gigabit-Switch-/360844573047?pt=UK_Computing_NetworkSwitches_RL&hash=item5404033977
An ounce of experience is worth more than a pound of enthusiasm.
« Reply #6 on: 29 January 2014, 23:20:25 »
Yep splitters just no good - you need an ethenet switch as others have suggested ;)
I_want_an_Omega
« Reply #7 on: 30 January 2014, 06:50:32 »
To be clear, this and other suitable devices will be powered - you cant do it any other way .........
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #8 on: 30 January 2014, 13:51:18 »
Cat5 cable has 8 wires which give 2 network connections. Only one is normally used, so yes you can use ethernet splitters to go from 2 to 1 and back to 1 to 2, but using all of the single cable wires.
What you need is a pair of these.
http://www.cmsplc.com/structured-wiring/base-tsplitters.html
or these from ebay
http://www.ebay.co.uk/itm/2X-RJ45-Splitter-1to2-Way-LAN-Network-Ethernet-Adapter-/370457128839?pt=UK_Computing_Other_Computing_Networking&hash=item5640f72f87
« Last Edit: 30 January 2014, 13:56:15 by Rods2 »
« Reply #9 on: 30 January 2014, 13:57:10 »
Yes, in fact, you don't even need those if you just wire two sockets on the faceplate at either end of the link, using two pairs for each, and remembering the colour scheme you use, of course.  ;)
I_want_an_Omega
« Reply #10 on: 30 January 2014, 13:58:39 »
or these from ebay
That will work if all 4 pairs are correctly wired all the way through, will require 2 ports on a device somewhere though - so may well serve the purpose properly.
« Reply #11 on: 30 January 2014, 14:15:41 »
It's also worth mentioning that if the devices at either end support gigabit ethernet they will require all 4 pairs to be connected and may even fail to negotiate down to 100mbit in that scenario.
« Reply #12 on: 30 January 2014, 14:24:09 »
Good look on the 'unused pins' bit for 100baseT, there is a LOT of things that happen to those pins including them being grounded in the terminating equipment.
And when you then think POE it gets worse!
« Reply #13 on: 30 January 2014, 14:47:37 »
I should add that if using the cheapo splitter types, you need one at each end of the cable (they are a way of getting two 100 base T ports over a single cable), this will would requrie two ports in your swicth/router at the head end
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #14 on: 30 January 2014, 16:30:09 »
As Mark says need one at each end, uses the the normally 2 Voice pairs for the second Data run, or you can make up your own with some spare Data Outlets. only good for up to 100 Mps T Base though.  :y
