Author Topic: Spark Plugs - Torque setting?  (Read 1540 times)
  • Auckland
    • Mazda MPV
« on: 01 February 2014, 22:12:01 »
Just changed mine.
Found that plug no3 had worked itself loose. :(
When I put the new ones in I couldn't find a recommended torque setting so I nipped them up and then gave them another 60 degrees (because it felt 'right').
Is there a 'correct' torque setting?
Re: Spark Plugs - Torque setting?
« Reply #1 on: 02 February 2014, 00:19:46 »
25Nm ;)
chrisgixer
« Reply #2 on: 02 February 2014, 09:07:42 »
25nm, then go over all 6 again.
  • Auckland
    • Mazda MPV
« Reply #3 on: 02 February 2014, 09:55:39 »
Car is all back together now. I have no intention of removing the inlet manifold, cable tray and coil packs again just to check the torque settings  :(
I am fairly confident that they are all tighter than 25Nm but I might go and play with a torque wrench (on the bench) just to reassure myself.
« Reply #4 on: 03 February 2014, 01:29:18 »
Never personally torqued spark plugs on any car - as you say tighten sensibly and all will be well - down to experience I guess :y
chrisgixer
« Reply #5 on: 03 February 2014, 01:32:12 »
As master said a while back, the washers on the plugs can relax after torquing. It's there for worth a re torque to make sure they are settled. Before it's put back together. ;)
« Reply #6 on: 03 February 2014, 01:46:20 »
If you change them regularly, they don't get time to work loose :y
Also no need to remove the inlet unless you're needing to get to the oil cooler/thermostat/coolant bridge :y
« Reply #7 on: 03 February 2014, 11:28:20 »
And having had to helicoil spark plug holes on three Omegas now for others after people thought they know how tight they need to be....I would recommend a torque wrench everytime (as it takes no extra time and means its done right everytime  :y)
« Reply #8 on: 03 February 2014, 11:57:56 »
Providing of course they know how to use one. Experience should also tell you to stop If the wrench has failed . . .which isn't unheard of
