Author Topic: gasket paper any good???  (Read 3685 times)
conalnugent
  • n. ireland
« on: 02 February 2014, 13:21:55 »
I dont know about the rest of the omegas but the 2.5td is a pain in the arse to find gaskets for and there dam expensive.  For example I need a set of inlet manifold gaskets and they work out about 6 quid each so timss this by 6 and its hardly cheap.  I remember complaining years ago about the 2.5 v6 inlet man gasket being £2 lol.
Anyways are the gasket paper sheets any good? What thickness and brands are reliable? IIf anyone could send me an ebay link That would be great. Also, what type/brand of instant gasket is good? They vary on ebay from 2 -15 quid.
Thanks
Re: gasket paper any good???
« Reply #1 on: 02 February 2014, 13:38:24 »
Of all the times I removed the inlet on my TD, I never damaged a gasket. So while I always kept a spare set on the shelf in case I did, they are robust enough to reuse.
conalnugent
  • n. ireland
« Reply #2 on: 02 February 2014, 14:03:09 »
The set I have on are only about 6 weeks old. I instant gasketed both sides. The old ones were baked solid. When reusing the ones that I put on a while back do I need to take the instant gasket off them and redo them or will it be ok just lifting manifold off and plopping it back on?
« Reply #3 on: 02 February 2014, 18:36:11 »
I never instant gasketted or anything like that.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #4 on: 03 February 2014, 17:02:46 »
IIRC someone suggested a while back that BMW gaskets were cheaper, but I may have made that up.:-\ CAF were £6.18 +VAT last year. :o
« Last Edit: 03 February 2014, 17:08:27 by Shackeng »
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #5 on: 04 February 2014, 01:36:44 »
Try your local Land Rover people ;)
« Reply #6 on: 04 February 2014, 09:17:18 »
I very much doubt paper gasket would be any good on a V6s inlets. The standard rubber gaskets can take up any misalignment between heads and I doubt a paper gasket would be compliant enough. There's also very little surface for a gasket to seal against. The abolition of paper gaskets is a key reason why modern cars generally retain their fluids rather than dripping them wherever they are parked, IMHO.
I too have never had a problem re-using the standard rubber seals, but I fit them with just a smear of oil or grease and never use any compound on them. Perhaps this is the key?
Seth
« Reply #7 on: 04 February 2014, 10:46:31 »
2.5TD dear boy. 2.5TD! ::)
Thanks
« Reply #8 on: 04 February 2014, 11:55:39 »
Gasket paper would work fine
« Reply #9 on: 04 February 2014, 21:56:41 »
Second most supported vehicles on the road, after the MGB ;D  ::)
BMW also (used to) have a discount scheme for cars over 4 years old... just need the reg/chassis number from a similarly aged 3/5 series :y
bootie
  • Enix, Almeria, Spain
« Reply #10 on: 05 February 2014, 19:46:06 »
What thickness?
I can get loads out here on the rig.....
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #11 on: 05 February 2014, 20:23:46 »
I used gasket paper once for a thermostat housing on a Nissan Micra in the work shop. It started and we ran it a few times and then found it leaking.
When I took it apart it was all soaked and acted just like, well, paper lol
Having said all that I have no idea whether it should be used in this application or what grade of paper it was so I can't say whether it was crap or whether I simply used it in the wrong application. but thought I'd share anyway  :)
RIP Paul Lovejoy
conalnugent
  • n. ireland
« Reply #12 on: 05 February 2014, 22:54:50 »
Ive found a place online that does the inlet gaskets.  All six for 10 including delivery. Will report back with pics and quality when they arrive.
« Reply #13 on: 06 February 2014, 11:42:37 »
Big difference between a cooling system and an inlet, for contact with liquids there is a different gasket type you use other than simple paper. :y
conalnugent
  • n. ireland
« Reply #14 on: 06 February 2014, 13:41:52 »
Now were learning.  :y
Can the coolant ones be got in sheet form
