Author Topic: what grease for door hinges?  (Read 4047 times)
SMD
  • London
    • :( nowt
« on: 02 February 2014, 18:51:03 »
So I have joined Detailing World and cleaned my door hinge (only had time to clean the drivers door). I have White Lithium Grease and WD40  ;D yes I know AndyB
But white grease is quite messy but I can try to spray it using the straw. If I was to remove the black cap and spray around the the hinge pin, would that work its way in?
I dont want to cover the outside of the hinge in grease like garages do to show they've done something.
kevinp58
  • kent
    • 2002 3.2 elite
Re: what grease for door hinges?
« Reply #1 on: 02 February 2014, 19:01:54 »
I always use the white grease with the straw and wipe the excess off.  :y
SMD
  • London
    • :( nowt
« Reply #2 on: 02 February 2014, 19:58:47 »
Do you spray directly at the hinge and do you think it penetrates into the important bits?
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #3 on: 02 February 2014, 21:11:56 »
I try to get the straw as tight as I can so it forces it in between the parts.  :y
SMD
  • London
    • :( nowt
« Reply #4 on: 02 February 2014, 21:38:56 »
Can I use dry motorcycle chain lube on car door hinges as its less messy than white grease?
« Reply #5 on: 02 February 2014, 22:15:49 »
 yes I know AndyB
It's others that have a problem with WD40  ;) ;) It has its uses, not many ...... but it has some.  :y :y
chrisgixer
« Reply #6 on: 02 February 2014, 22:24:35 »
You can, but it tends to be sticky to prevent it flying off. White lithium grease IMO.
Squirt and wipe. ;)
SMD
  • London
    • :( nowt
« Reply #7 on: 03 February 2014, 01:39:16 »
Thanks. lithium grease it is.
Does the check strap bush need lubing too?
chrisgixer
« Reply #8 on: 03 February 2014, 01:42:56 »
Can't do any harm. But the rollers on the spring in the door are the important bit. Difficult to get to, even with a a straw on the aerosol.
Personally, I don't think it actually needs much lubing, other than those little rollers.
chrisgixer
« Reply #9 on: 03 February 2014, 01:50:39 »
What did detailing world say about cleaning btw?
SMD
  • London
    • :( nowt
« Reply #10 on: 03 February 2014, 07:09:42 »
About how to clean or what products to use?
All purpose cleaner such as daisy or Flash and a stiff brush plus a lot of elbow grease. It took a lot of effort to remove the stubborn grease from the drivers side alone. Most likely that it's never been cleaned before.  Last night discovered Bilt Hamber APC is supposed to work very well so will order one to tackle the rest.
http://www.detailingworld.co.uk/forum/showthread.php?t=112073
chrisgixer
« Reply #11 on: 03 February 2014, 08:32:13 »
Might try that, I used gunk on mine. Didn't even touch it.
SMD
  • London
    • :( nowt
« Reply #12 on: 03 February 2014, 09:00:32 »
ill post some pictures tonight
I used gunk too. It was next to useless. Flash (kitchen all purpose) was much better but still required a lot of work.
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #13 on: 03 February 2014, 18:44:19 »
Is it clicking ? if so grease won't stop it you need a new plastic bush only pennies from the dealer  :y
SMD
  • London
    • :( nowt
« Reply #14 on: 03 February 2014, 20:27:58 »
Got half dozen of them under my bed  ;)
