Author Topic: Techy Question for the V6 Nerds  (Read 2561 times)
Sam Burton
  • St Neots, Cambridgeshire
  • Just Car Mad Really
    • Many
« on: 03 February 2014, 15:48:27 »
Hi Guys,
Went to test drive a 2001 2.6 V6 Auto CDX today drove lovely with a few battle scars on the bumpers so nothing that cant be fixed, covered 102000 so not massive came from a Hire car company and the inside is in fantastic condition but theres something that put me off the deal that i want to run past you guys first before i buy,
Ive already spoken to RobG (which i am massively thankful) and he said high possibility it could be knock sensor but he wasnt 100% sure
Can any of you guys rattle your brain and tell me what it is and let me know if its any easy fix.
Its a Single Wire Black outer casing with a green outer sheath which i foil backed the wire itself is white. Where should it be connected.
I did the Pedal Trick on site (thanks RobG) and it has no codes.
Sam
Drives: 2015 Vauxhall Cascada Elite 2.0 CDTI Auto, 2006 Vauxhall Vectra 2.8T VXR 'Ex-Police' Build, 2010 Vauxhall Insignia 2.8T VXR Saloon, 2017 Vauxhall Insignia Elite VX Line Sports Tourer 2.0 CDTI Auto
Re: Techy Question for the V6 Nerds
« Reply #1 on: 03 February 2014, 16:08:23 »
Yeah I'd go with knock sensor as well
« Reply #2 on: 03 February 2014, 16:09:38 »
There should be a plug on the front cable tray which is the other end of it
Sam Burton
    • Many
« Reply #3 on: 03 February 2014, 16:12:23 »
xso whats the easiest thing to do replace or can i not?
Sam
« Reply #4 on: 03 February 2014, 16:36:06 »
Knock sensor, that tells me the cambelt has been replaced by somebody who did not route the knock sensor cable correctly when the aux tensioner was re-fitted.....the result is a cable that has made its way into the aux belt and been trashed.
They can be joined if your good at soldering, or replace it.
To replace, its easier to pop the alternator off its top mount to get access.
I woudl expect the engine managment light to be on with such a fault once the engine is revved slightly and it would be very down on power.
« Reply #5 on: 03 February 2014, 17:06:13 »
Piccie of O/S knock sensor Sam
Sam Burton
    • Many
« Reply #6 on: 03 February 2014, 17:12:00 »
Right guys thanks ever so much for your help, So if i resolder or replace the wire how do i go about rerouting it properly
Sam
« Reply #7 on: 03 February 2014, 17:17:20 »
Cable routes behind the tensioner and up around the timing cover. Failsafe way is to remove tensioner to ensure correct routing
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #8 on: 03 February 2014, 17:56:17 »
This happened to me when I first changed the cam belt on a 1999 3.0 V6 Omega. I made a meal of the job, replaced the aux belt tensioner before I realised I had a lead hanging around, so plugged it in as best I could. After 1000 miles or so the EML came on, message was Rh knock sensor. I resoldered the lead and rerouted it, all was well.
« Reply #9 on: 03 February 2014, 18:00:17 »
If repairing, try to keep the integrity of the coax as much as possible
Sam Burton
    • Many
« Reply #10 on: 03 February 2014, 22:17:02 »
Ive managed to source a Knock sensor locally can someone confirm the GM number I have : 0261231116
anyone confirm.
« Reply #11 on: 03 February 2014, 22:35:48 »
anyone confirm.
