Author Topic: Q about a new boiler  (Read 4091 times)
Taxi_Driver
« on: 04 February 2014, 18:30:34 »
Im thinking about getting one of these
http://www.viessmann.co.uk/en/flats_apartments/Product/Gas_condensing_boilers/vitodens_100-w_compact.html
Plumber has told me he will have to replace the 15mm gas pipe going to my old boiler with 22mm....which is quite a bit of work involved.....ie ripping up floorboards...
My question is having looked at the install instructions on the boiler it says the gas connection is 1/2in male iron ?? Now that is 12.summat mm ..... so should the 15mm gas pipe i already have be ok  :-\ Im probably missing something here  :-\
martin42
Re: Q about a new boiler
« Reply #1 on: 04 February 2014, 18:32:17 »
Its just a standard 1/2 " iron to copper fitting thats used  :y
Gas run is normally run in 22mm until about the last 1.5 m away from the boiler
Taxi_Driver
« Reply #2 on: 04 February 2014, 18:42:54 »
Ah ok...thanks for that.....even tho the plumber couldnt see under the floorboards....he reckons the 22mm pipe that comes into the house goes down to 15mm somewhere halfway thro the house which is about 8m short of the boiler......so he's correct then  :y
I_want_an_Omega
« Reply #3 on: 04 February 2014, 22:05:40 »
He should have done a test at the boiler location to determine that - you can't get as "much gas" though 15mm compared to 22mm pipes. Think of it as the really thick wires going to a starter motor .........
« Reply #4 on: 05 February 2014, 00:19:43 »
At low (relative) pressure........... ;)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #5 on: 05 February 2014, 09:29:10 »
Or drinking the contents of your Home Brew Container through a Straw.  ;)
« Reply #6 on: 05 February 2014, 09:42:59 »
So can somebody explain how any length of the pipe being 15mm is allowed....(assuming no other device is T-d off the pipe), or are we in the world of gas fitters logic  ;D
As an example, do you think you could drink your home brew easier through a long thin straw or a pipe of the same length which was f-large for 3/4 of the run with the remaining 1/4 being the same thin straw size....
« Reply #7 on: 05 February 2014, 09:47:51 »
Indeed. you could run the gas main directly up to the fitting on the boiler, but if it's only 1/2 in. guess where the restriction will be... ;D
I'd be downloading the installation manual for the boiler and checking that, TBH. Then you can get the gas fitter to explain the logic behind ignoring what it recommends. Oh, and ask him how he's going to stop the condensate drain from freezing too, if you fancy a laugh. :D
« Reply #8 on: 05 February 2014, 09:55:59 »
I'd look at getting rid of all the old iron gas supply pipe while your at it, and get your fitter to run 22mm copper back to the meter.  Last year my Mum had a nasty gas leak where a joint in the old iron pipe had rusted and failed.  ::)
zirk
  • Epping Forest
« Reply #9 on: 05 February 2014, 10:45:01 »
No idea Mark, but if its someone else's Beer and its free, Im up for the test experiment.  :y
« Reply #10 on: 05 February 2014, 10:46:40 »
« Reply #11 on: 05 February 2014, 10:57:16 »
I think they fit a little electric blanket around them these days.  ::)  ;D
« Reply #12 on: 05 February 2014, 12:33:07 »
Ahh.  ::) anything to avoid Please read the manual!
I_want_an_Omega
« Reply #13 on: 05 February 2014, 17:01:06 »
When we wanted our new boiler installed BG gave us a quote  :'( . After I'd got off the floor I went through it with the guy and sought explanations for some of the nonsense that was included.
The new boiler was to be about 15m further away from the meter than the old one, but on the other hand, the main gas run went onto feed 2 x 5Kw gas fires - which were to be removed at the same time
Part of the quote was to increase the size of this main pipe from 22mm to 35mm  ;D. They point blank refused to take into account the fact that the two fires were being removed.
A local guy got the contract, he took the fire removal into account and was more than happy with the pressure & flow rate of the 22mm pipework which then ran all the way through to the boiler location.
Ever Ready
  • Scotland
    • 2.2 CD Auto, Pug 308Hdi
« Reply #14 on: 05 February 2014, 18:06:50 »
BG do tend to extract the Michael :)  I have always seen 22mm used to the boiler on new builds or upgrades from old 'vintage' boilers to more modern ones, although the manual that comes with your new boiler should give you some guidance.
As far as I remember the problem is often gas flow rather than gas pressure which is normally 20 millibar
An ounce of experience is worth more than a pound of enthusiasm.
