Foolish jump lead connection
Started by f3nt0n, 04 February 2014, 18:36:34
f3nt0n
I recently tried jump starting my VW Golf (flat as a pancake) with my Omega. Made a real rookie mistake - connected the + to - across the two batteries. Tried to start the Golf, the Omega nearly conked out and the Golf smelt of burning (a bit). Realised my mistake and after much cussing at the stupidity of me, reconnected (the right way round) and the Golf started first time. BUT the Golf battery light is on and it conks out as soon as the jump leads are disconnected. The alternator is no longer spinning round.
I've !&!*ed the alternator on the Golf, haven't I?
martin42
Is the auxiliary belt still on the alternator?
tidla
The pulleys on vag brands do fail resulting in the alternator freewheeling and eventually falling off. Probably why it went flat unless you know other wise?
If the battery is that flat then it will stall. bench charge, refit and test charge rate.
Quote from: f3nt0n on 04 February 2014, 18:36:34.. The alternator is no longer spinning round.
??? ??? Not sure what you mean ..... is the 'fan belt' still intact?
f3nt0n
f3nt0n
Quote from: tidla on 04 February 2014, 19:08:13
It went flat (I am supposing) because it sat around without being used for a year. Cheers.
f3nt0n
Quote from: Andy B on 04 February 2014, 19:11:51
I might be wrong but I thought that inside the alternator, the 'wirey bits' spin round while charging the battery. They don't spin any more (if they did in the first place). Thanks.
henryd
Quote from: f3nt0n on 04 February 2014, 19:51:08
No the wirey bits stay still  :y
other rides
Where are you looking  ...... the bottom right (as you stand in front of the car) is the a/c compressor and the middle bit doesn't spin unless it's engaged. The alternator pulley is always spinning irrespective of how much the alternator is charging.
Quote from: Andy B on 04 February 2014, 20:34:38
All very interesting, but what of the Golfs' alternator  ::)
Quote from: Taxi Al on 04 February 2014, 21:05:29
Ooops!  ::) ::) ::)
And some VAG alternators have a clutch, so only engages when the electrics tell it to.
Though thought clutch was ecu controlled. Which could be expensive. Can VAG experts confirm?
r1
why do people still jump cars this way?
dosnt anyone read the handbooks with there cars?
