wind deflectors
Started by dillan, 04 February 2014, 21:17:59
dillan
has anyone got any pictures of there omega with team heko  wind deflectors ?
plz share :)
biggriffin
Try climair, they do loads. They are in Kent (sidcup)
Hoof'land storeman.
jonny2112
I don't think they're too common as they have to be stuck on due to the nature of the door construction.
biggriffin
Climair ones fit inside the channel. Fit loads to trucks.
Hoof'land storeman.
jonny2112
But the omega doesn't really have proper channels, that's the problem  :-\
Am I missing the point? If the windows are open, its because you want the airflow to come through...   ...or your name is webby the bear at the Drive Thru
I've always found them annoying, cumbersome, noisy and look pikey (although that last bit is subjective, obviously), with no upsides  :-\
Put me out of my misery, please?
dillan
there front when its raining n u want the window down slightly wiv out getting rained on
Quote from: dillan on 05 February 2014, 21:09:09
??? Could someone translate please ???
Hint ...  http://www.omegaowners.com/forum/index.php?topic=90684.0
Sorry, I couldn't make sense of what you said  :-[
dillan
Quote from: TheBoy on 05 February 2014, 21:15:40
for *
Quote from: dillan on 05 February 2014, 21:21:49
for *
They're for when its raining, and you want the windows down slightly without the rain coming in
Is that right?
That's about the bones of it :y
Right, now we have that settled, I still can't see the benefit  :-\.  If its raining, I probably don't want that airflow on me, so will use the ventilation system's airflow  :-\
Don't get me wrong, on a summers day, I like the windows and sunroof open. But still stuggling to see any benefit of wind deflectors.
Good luck with your search, all the Omegas I've seen with them were fairly unsuccessful in that securely fixing them was a pain.
chrisgixer
I was going to post on this, so would probably be post 2. Glad I didn't bother as its gone the way I would of posted anyway. ;D
What on earth for? Only thing I can think of is no or failed ac to stop the windows steaming up. Why else would anyone drive with the windows down in the rain...?
Fix the ac. Or open the rear window as well slightly, that way you get airflow not buffeting.
Ghastly bloody things. But each to their own.
