Author Topic: replacing clutch pipe into master cylinder  (Read 1451 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 05 February 2014, 12:22:15 »
OE03 EWW 3.2petrol manual saloon
I have obtained a new retaining clip and with some difficulty inserted it in the the master cylinder output pipe. I find I cannot insert the pipe into the cylinder. A heater hose restricts access. Is it just that the angle is wrong, or do I have to remove the clip again to get the pipe in?
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: replacing clutch pipe into master cylinder
« Reply #1 on: 05 February 2014, 16:53:36 »
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 05 February 2014, 19:39:10 »
Thanks Seth. I have removed, and lost, my new clip. I still cannot get the pipe in. I think it must be alignment. The heater pipe make it difficult to get the pipe straight.
« Reply #3 on: 05 February 2014, 20:07:03 »
Does the pipe and fitting from master to box sit level and flush against the bulkhead :-\
If yes, the heater hose is dislocated, if no then pipe is not where it should be :-\
terry paget
    • 3 Astras 2 Vectra
« Reply #4 on: 05 February 2014, 20:28:32 »
No. the pipe is coming vertically up, and the ninety degree bend is caught under the heater hose. I think before the pipe came horizontally out from the bulkhead before turning 90 degrees to face the master cylinder. I will check with the 2.5 in the morning. I suppose it must pass above one of the heater hoses.
