Author Topic: power difference  (Read 956 times)
dillan
  • kent
    • omega 2.5 v6
power difference
« on: 08 February 2014, 10:36:05 »
what would the power difference be between a 3.0L with 4xg cams chipped ecu to a 2.5 with 4xg cams 3.0l chipped ecu 3.0L lower n upper manifold intake things (cant Remember the name) 3.0l injectors 3.0L exhaust manifolds redtop flywheel 7kgs
is there much difference?
Re: power difference
« Reply #1 on: 08 February 2014, 10:55:06 »
Without punctuation, I can't make out what you are trying to compare  :-[
If its the difference between a 3.0l and 2.5 running g cams, quite a lot. I've owned both, and the 2.5 was noticibly down on power, esp mid range.
Fitting overly large injectors for the application may upset the ecu, as it may not be able to trim them back enough to stop overfuelling
