Author Topic: Rear coil springs  (Read 1660 times)
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
Rear coil springs
« on: 08 February 2014, 20:17:59 »
Do I need heavy duty rear springs for my MV6, or will standard one do? It's not the self levelling type.
chrisgixer
Re: Rear coil springs
« Reply #1 on: 08 February 2014, 20:23:27 »
Either will work but it will sit higher, and be slightly softer. I'd suggest the handling won't be as good.
  • Auckland
    • Mazda MPV
« Reply #2 on: 08 February 2014, 20:32:49 »
I thought Vauxhall referred to the MV6 chassis as "lowered sports chassis" or "LSC"
"Heavy Duty" springs are probably going to be normal length but stiffer than standard.
LSC springs are shorter and stiffer than bog standard.
« Last Edit: 08 February 2014, 20:37:08 by Andy H »
« Reply #3 on: 10 February 2014, 08:17:17 »
Is if facelift or prefacelift? FL ones use LSC springs, only available from dealer. These are 15mm lower, and stiffer.
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
« Reply #4 on: 10 February 2014, 15:54:47 »
Hi, It's a pre-face lift, will that be standard size? Also is there any big differebnce between Sachs and Anchler springs?
« Reply #5 on: 10 February 2014, 16:40:42 »
Budget
« Reply #6 on: 10 February 2014, 17:24:57 »
Sach or Boge are good makes, and worth paying a few quid more for.
