£93.33.
Started by Field Marshal Dr. Opti, 10 February 2014, 16:27:40
This is the amount I've received for 4 full months of tax remaining on my SORN MV6.
Is this correct?
You can't trust the bastards, you know. ::) ::)
Sound about right  :-\
That'll nearly be enough for a tank of petrol  ;)  ;)  ;)  :y
Quote from: Andy B on 10 February 2014, 17:40:50
Once the cheque has cleared :D
Ever Ready
Maybe half a tank by that time ;D ;D
An ounce of experience is worth more than a pound of enthusiasm.
I'm getting almost 20 MPG out of the CLS. So who needs a diesel? ::) ::) ::) ;D
It seems to have two of almost everything. Two air filters and two batteries so far. ::) ???
Quote from: Mr. Opti on 10 February 2014, 18:52:01..... Two air filters and  .....
Don't know about yours, but the two air filters on mine are a tw@ to fit! Though there's only one battery on mine, it lives under the driver's seat which apparently needs to be removed to remove the battery.  ???
Quote from: Andy B on 10 February 2014, 20:36:41
Air filters are relatively easy to get at, Andy....... and cost about £15 for the pair from Ebay.
As for batteries ......it has a 12V 95 AH battery in the boot, and a 12V 12 AH battery under the bonnet. This is about the size of a motorcycle battery.  :y
Quote from: Mr. Opti on 10 February 2014, 22:36:43......
I've seen pictures of them on another  ::) forum  ;)  ;)  ;)
Quote from: Andy B on 10 February 2014, 22:54:44
So, have they got 2 dissimilar lead acid batteries bodged in parallel, fighting each other, because they found they couldn't get enough current up from the boot to start it, or is it more clever than that? ::)
Quote from: Kevin Wood on 11 February 2014, 09:33:50
I'm sure it's much more cleverer than that  8)
Pretty sure the little one up front is nothing to do with starting.  ;)
Quote from: Andy B on 11 February 2014, 11:54:27
The handbook refers to the smaller battery as 'auxiliary'.......whatever that means. :)
Quote from: Mr. Opti on 11 February 2014, 13:14:51
The best I can find by search A N Other forum  ::) is that it's for your SBC braking ( ....... before it breaks & leaves you with a £££££££££££££££££s bill  ??? ;))
Quote from: Andy B on 11 February 2014, 14:17:26
Please.....not even in jest. ;D ;D ;D
Knowing the incompitence of Merc/AMG designers, I fear Kevin Wood may be nearer the mark...
