Vectra B Engine ECU location ?
Started by zirk, 10 February 2014, 20:52:48
zirk
Vetra B Hatch 99 2.0L anyone know, cant see it in Engine Bay, looked behind both Kick Panels, where is it?
Under nearside scuttle lives inside a rubber casing secured with 4 x 10mm nuts
zirk
ok thanks Rob, found it your right 4 10mm nuts then another 2 holding the ECU in, but it wont come out looks like theres another back plate behind bolted to it all not big enough to pull through the hole.  :-[
zirk
#3
Ok sorted, no way was that ECU coming out, about to give up I decided a cuppa was in order, and whilst pondering over my tea and fag at the back of the this Vectra Im staring at the Badge on the Boot 'Dual Fuel', as its a Factory Fit LPG !
So Im thing have the cheeky bastwards at Factory bolted an LPG ECU on to the oringinal, so Glove Box out, Air bag out, Yep, LPG ECU bolted on the back of the Mototronic one, bundled with tapped up Relays etc, without out all this crap attached to it, the Engine ECU.would have just pulled out of the slot from the Engine Bay Slot as Rob Suggested.  :y
Ah well, alls well that ends well  ::)
