Replacing Omega handbrake shoes
Started by Shackeng, 11 February 2014, 17:41:43
Id like to do my handbrake refurb in about an hour but i think it will be more like 5-6 and mucho swearing  ::) especially that bit where you try and poke through and loosen the shoe  :(
Quote from: Emd on 17 February 2014, 07:09:43
I hate that bit.. it was even worse on the Jag as some plonker had put the disc on upside down leaving no hole to go through to get to the adjuster  ::) Took a three leg puller wedged on the disc and a very loud bang before the disc came off .. taking the brake shoe material with it ;D
Shackeng
Quote from: aaronjb on 17 February 2014, 11:30:20
Wot? no locating screw???
Quote from: Shackeng on 17 February 2014, 13:47:41
Nope, not on the XJ40 with outboard discs; the hub (with disc off and handbrake mech visible) is on the left here: http://img811.imageshack.us/img811/5454/x308e.jpg
There's two (extra) holes in the disc, one of which should line up with the hole in the hub.. but it's possible to put it on so that neither hole lines up. Which was annoying..
Although seeing as the hubs are still in bits in the garage, of no great concern besides the enormous bang it made coming off.. ;D
Shackeng
