Replacing Omega handbrake shoes
Started by Shackeng, 11 February 2014, 17:41:43
Shackeng
I have just completed this job on the TD Estate, using Mark's how-to, so I am extremely impressed that he enjoys doing it so much that he does it every two years according to this: http://www.vauxhallownersnetwork.co.uk/index.php?threads/how-to-service-the-rear-brakes-on-an-omega.95836/! :o
The 15 year old shoe linings are 1mm less than the new! My advice, always put it in for the MOT one month early, and only ever tackle this job if it fails on the handbrake, which mine never has in 15 years!
If anyone hears me suggesting that I am about to do this job again, kindly pop round and give me a poke in the eye with a sharp stick, which will be somewhat more enjoyable!!! >:( >:( >:(
Some of us have to do it annually. Horrid job.
GastronomicKleptomaniac
Quote from: GastronomicKleptomaniac on 11 February 2014, 18:04:13
Quote from: TheBoy on 11 February 2014, 17:57:19
Why's that then?
Because its a shit system ;D
And, yes, I use it every single time I park, in order to prevent it seizing...  ...unsuccessfully.
YZ250
Quote from: Shackeng on 11 February 2014, 17:41:43
;D ;D
Not one of your favourite jobs then.  ;D
Quote from: TheBoy on 11 February 2014, 18:15:48
Why's that then?
But any hand brake/parking brake is/should only be used when the car is stopped. So how do you wear linings by squeezing them against a stationary drum?  ??? ??? ::)
I'm trying to wean myself off using the handbrake but force of habit is strong. ::)
Why? Oh, it doesn't always release. :-[
Don't worry - it's "on my list" but it has just passed the MOT, so... ::)
Few handbrake turns free's it up  :P
Quote from: Andy B on 11 February 2014, 18:21:59
Why's that then?
I have never worn it out.
And technically, its also a secondary braking system, so needs to be able to shave off speed in an emergency
Quote from: TheBoy on 11 February 2014, 18:34:30....
Is it?  :-\ Sure it's more of a parking brake.  ::) You'd be better off sticking your foot out of the door in my Merc than try to use the foot operated parking brake  ;D ;D
Quote from: Andy B on 11 February 2014, 18:47:12
Yeah, apparently.  Some newer cars have get-out/loophole clauses to get around this.
Shackeng
I always put it on when I park, but rely on the park mode of box to hold it. As stated, 1mm wear in 15 years! And never failed an MOT. I rest my case m'lud. ::) ::)
2woody
its not that difficult.
fifteen minutes per side or so.....
there are very many more difficult ones to do than that.
But, my record is having to remove the body from the chassis to change the EGR valves on a Discovery 3
Quote from: 2woody on 11 February 2014, 21:00:17
Mine always needs everything cleaned up fully, so nearer 1hr per side.
Didn't take too long then  :)
