Author Topic: What PVA mix for garage floor?  (Read 1525 times)
« on: 13 February 2014, 13:09:12 »
So in the coming days I plan to seal my new garage floor, plan to use PVA glue to water mix.
Question is what ratio? Done a bit of Googling, various results.
Always get good advice here, thinking 50/50?
2L PVA in a bucket, then 2L of water? Mix it up, then apply using a broom? Or is it better using a masonry brush to really work it in? (It's a standard single garage)
Re: What PVA mix for garage floor?
« Reply #1 on: 13 February 2014, 13:14:55 »
Be sure to sweep the floor several times with a soft brush, so that the floor is as dust free as possible before starting :y
Half and half in a bucket will be ideal for mixing :y
Would probably use a large paintbrush, say a 5-6" one... too large and you're less likely to get it evenly distributed :-\
« Reply #2 on: 13 February 2014, 13:30:20 »
Cheers. Sounds good :)
« Reply #3 on: 13 February 2014, 13:50:54 »
Run your vacuum over it as well, after sweeping.  ;)
redelitev6
« Reply #4 on: 13 February 2014, 20:52:25 »
I would give it 2 coats, first one 75 water 25 pva , this gives the second coat a good base to stick to
