Author Topic: Rough 3-4 gear change  (Read 3480 times)
« on: 13 February 2014, 18:29:43 »
Since tranny change,
Car now goes forward and doesn't lose drive ;D
The changes are all fine, including 3-4 under light driving, however when giving it large say on overtaking, and then backing off, the final 3-4 change is quite jerky
Solenoid? The 1-2 change is perfect tho, and I think this solenoid is shared?
ATF new, sumps clean, thrust washer intact.
Opinions welcome :y
Re: Rough 3-4 gear change
« Reply #1 on: 13 February 2014, 18:31:26 »
Are you used to the less refined 3.2's TCM, compared to the superior 3.0l setup?
« Reply #2 on: 13 February 2014, 18:32:44 »
It's a 3.0 car, all factory original, the box was from a '02 3.2 v6
Does that help? :y
« Reply #3 on: 13 February 2014, 18:32:52 »
I should add, that 129mph change from redline 3rd to 4th is awful if you lift off and reapply power. As is the 85mph 2nd-3rd, just not quite as pronounced
« Reply #4 on: 13 February 2014, 18:34:15 »
Does that help? :y
Ah, should be reasonable then. Can still force a (what we call) lag, but not as much as 3.2. If LPG comes in to equation, that makes it worse
« Reply #5 on: 13 February 2014, 18:35:27 »
Does that help? :y
No LPG on this one, just petrol
I'm thinking solenoid issue
« Reply #6 on: 13 February 2014, 18:37:11 »
Does that help? :y
I noticed from you wanted post. Not convinced currently, as TCM would flag it
« Reply #7 on: 13 February 2014, 19:06:53 »
Does that help? :y
I shall double check all codes and data - are you thinking mechanical issue then?
chrisgixer
« Reply #8 on: 13 February 2014, 19:09:24 »
Why does James have so much agro with autos?  :-\
Touch wood, but never seen a fault with an auto beyond thumpy changes cured with a fluid change.
Got live data on the box? Thought 3-4 was replaceable. Tbh.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #9 on: 13 February 2014, 19:16:04 »
TB, you did 129mph in 3rd  :o Where on Earth were you able to achieve this? Autobahn???
RIP Paul Lovejoy
« Reply #10 on: 13 February 2014, 19:36:20 »
Redline 3rd to 4th is a shade under 130mph.
Heyford's runway is a long one :)
Webby the Bear
  • Northampton
« Reply #11 on: 13 February 2014, 19:40:44 »
Good stuff. I've never heard anyone getting their Omega close to top speed (only because I've never asked).
What did it feel like going that fast in it?
RIP Paul Lovejoy
« Reply #12 on: 13 February 2014, 19:47:57 »
1-2 solenoid also controls 3-4/4-3 shift so given you say the 1-2 change is OK it`s doubtful that the solenoid would be at fault ???
« Reply #13 on: 13 February 2014, 20:12:56 »
Why does James have so much agro with gearboxes?  :-\
Fixed...
« Reply #14 on: 14 February 2014, 08:13:15 »
Shockingly smooth and quiet....
Page created in 0.011 seconds with 14 queries.
