Is my engine worth anything?
Started by Martin_1962, 14 February 2014, 20:42:14
Martin_1962
Keeping hold of it just in case I buy a car which needs one. But want to know if it is worth anything.
Y26SE
3.0 cams & divider
ported inlet tracts
Only 164,000 miles
Oil cooler, thermostat in 2009
Car was not far off 3.0 performance it could beat 8 seconds to 60.
Stemo
Only 164,000 miles? Bugger me, it's brand new  ;D
In a word no but you might get a couple of quid for the cams and exhaust manifolds
chrisgixer
A 2.6?
Cams and inlet out. Coil pacs out. Scrap the rest...?
blackviper90210
How much do these engines weigh roughly?
Contemplating looking for a scrap engine to learn on. Not being a mechanic and not much space whilst in the car, would love the opportunity to "play" with one.
AKA - Mr Bracket
chrisgixer
biggriffin
Ar 25 worth £40 tops AR 35 worth more.
Hoof'land storeman.
M Kerr
If its out of the car and you've got the space (and a little time) it would be pretty easy to do a full recon.  Got to be worth a few quid then.  ...I'm full of great ideas I know... Maybe Black Viper's the man for the job.
Quote from: M Kerr on 15 February 2014, 20:27:48
At that mileage a proper recon would cost way more that you'd ever sell it for, IMHO.
As said, cams are worth something, possibly the heads if someone happens to have a cam belt failure, coil packs are a frequent failure, hence worth something second hand. Then you're really struggling to find any value in what's left. As a complete engine with that mileage, even less IMHO.
Even now they're this old, Omegas rarely die due to engine failure, hence nobody is in the market for a complete engine, and if they were, I'd wager they'd find something with less miles quite easily. :-\
M Kerr
Point taken Kevin.  I would have thought though that, assuming the periferals were reusable, that a good eneral strip down, cleaning and rebuilding with new seals, apart from the labour element cost wouldn't be that great.  If reconned thoroughly, is mileage of any significance?  I'll bow to your knowledge.
All the best,
Martin
Drop it in a Westfield chassis with twin side exit pipes 8)
Depends how far you're going to go, really. In my books, if you're going to sell it as a refurbished engine you're looking to restore it to as close to "as new" as makes no difference. At 160k miles that will mean a complete set of gaskets and seals, lapping the valves in, cleaning all the tappets and possibly replacing some, piston rings and either a hone or rebore with oversize pistons and possibly bearings and a polished crank.
Then you've got the convince a buyer that you've done all the above and done it well.
If you're not going to go that far, it may well stay together as Ellesmere port assembled it, IMHO.
chrisgixer
Quote from: biggriffin on 15 February 2014, 12:41:19
Thought they had 35. Whoppsy. :(
Quote from: Taxi Al on 15 February 2014, 21:43:38
Agreed, but then you'd be mad not to bide your time for a 3.2. :-\
Same (considerable) weight and cost, bags more power. :y
As others have suggested, the cams are probably worth more that the entire engine.
Anyone looking to replace and engine for performance reasons will shove in a 3.2, as its more powerful, and delivers the power better than a 2.5/2.6 with 3l cams.
Anyone wanting an unfettled replacement engine due to failure will want one not messed around with, and lower mileage.
