Author Topic: URGENT QUESTION 2-4-6 coil pack  (Read 1289 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 15 February 2014, 11:49:57 »
Just picked up my bits for the cam covers / oil cooler, pulled away and half the pigin engine stopped working  >:(
Same on petrol and lpg.
Plugged in  :-X  code reader to find misfire cylinders 2 / 4 / 6 and random misfire (can't remember the codes)
Question is ............... do these coil packs tend to just go pop and wipe out all 3 sparks in one go or is it a gradual thing ?
Is they anything else it may be before I throw my toys totally out of the pram and buy a coil pack ?
  • Auckland
    • Mazda MPV
Re: URGENT QUESTION 2-4-6 coil pack
« Reply #1 on: 15 February 2014, 11:58:03 »
I *think* they have a common 12 volt supply and individual connections to the 0v/ground/earth terminal from the ECU. If the supply is missing then all three coils will stop working.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #2 on: 15 February 2014, 12:00:01 »
Mmmm, best remove the scuttle and look at the plug then  :y
Thanks Andy
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #3 on: 15 February 2014, 12:37:54 »
Spot on Andy  :y
Last time I was under there, the plastic cage on the plug fell apart  ::)
The plug had worked its way loose and had fell out  :-[
I'll glue it in when I do the covers / oil cooler next week  :y
Page created in 0.063 seconds with 16 queries.
